1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support Miller Import Parts
Street Build Vdubzr32's Talon TSi AWD
Year:
1996
Model/Trim:
Eagle Talon TSi AWD
  • Ownership Status:
    I own it
    Turbo Type:
    GT35 Variant
    Drivetrain:
    AWD
    Transmission Type:
    Automatic
    Build Type:
    • Street
    Mods-Bolt-on:
    Slow Boy Fmic short route, Mishimoto Fans, 2g alum. Radiator, NRG Bov, 255 wal. Pump rewired, Afpr 43psi, FP cold air intake Green filter, Speed Density, HBC, evo3 intake manifold, 1g 63mm throttle body, PTE 1200cc injectors, emissions removed,Archer Fab T3 manifold, GT35R BB, 44mm Tial Wastegate w/open dump
    Mods-Engine:
    6 Bolt Blue Printed 8.5:1 compression, Weisco HD 1400 Pistons .40 /Manley Turbo Tuff I beams Rods , Polished Balanced Crank balance , Rebuilt head, 272 HKS Cams, Kiggly Bee Hive Srings, Evo 8 Retainers, 4 Layer head gasket, Arp head studs, new oem timing belt kit,
    Mods-EMS & Logging:
    Mtx Boost gauge
    Mtx-l wideband
    Mtx-l oil pressure
    EcmLink v3
    Mods-Drivetrain:
    Automatic rebuilt transmission, shift kit installed, 3G Manumatic Shifter, Force Four shift box, restall Converter, No TCU
    Mods-Handling:
    EBC Slotted Rotors Green Pads
    Gr2 excel struts front/rear
    Eibach pro. 1.3 inch drop
    Background:
    Has spun bearings on two 7 bolt motors already. Last and final attempt building it.
Share this Item
User Comments
  1. grace647
    this is beauty. i love it
  2. Chumpaumpalumpa
    I love that copper on green look man. Looks awesome
    1. Vdubzr32
      Thanks Bro.
      Vdubzr32, Oct 6, 2015
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
