1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Street Build UnBR33's Eclipse
Year:
1997
Model/Trim:
Mitsubishi Eclipse N/T
  • Ownership Status:
    I own it
    Drivetrain:
    FWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    Stock, presumably
    Mods-Engine:
    Stock, presumably
    Mods-EMS & Logging:
    Stock, presumably
    Mods-Drivetrain:
    Stock, presumably
    Mods-Handling:
    Stock, presumably, needs shocks replaced on front end
    Parts Wishlist:
    EVERYTHING to convert to a GSX, which won't be cheap or easy, I'm sure.
    Background:
    I have experience in '60's and '70's muscle rebuilding and converting, but not for DSM, and I'm looking to make my pretty Black Betty into a GSX from a base model Eclipse.
    Bought it and imediately had to replace Cam bearings, cyl 2 sheared, and there seems to be an oil burn problem, I presume from the straight piping,to be frank, but I'm not sure at all. I wouldn't have straight-piping it myself, but I bought it that way.
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
