- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT35 Variant
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Turbo: PTE SCM-6152E Turbo, FP DSM Race Manifold, Buick Regal Modefied HD Wastegate
Intake / Exhaust: FP DSM Aluminum Intake Pipe, 1G Intake Manifold, 1G Throttle body, Megan Racing Downpipe, SSAutoChrome Catback V1, , SSAutoChrome FMIC, GReddy Type-S BOV, Modified Vibrant Catch Can.
Fuel: Walbro 450 LPH, Fuel Lab AFPR, -8AN Tank to Rail, -Stock Return, Fuel Lab E85 SS Filter, Lucas 1200 cc Injectors.
Cooling: KOYO Half Rad Kit -12AN Lines, STM Evo 8 Coolant Overflow
Other: Odyssey PC680 small battery with custom mount.
- Mods-Engine
- Engine Internals: Manley 10.5 CR Pistons, Manley Turbo Tuff Rods w/ ARP625 Rod Bolts. ARP Main Studs, ARP L19 Head Studs, OEM Crank Resurfaced by TW Automotive & Machine, Block Honed & Decked by TW Automotive & Machine.
Engine Accessory: Fluidampr Harmonic Balancer, Gates Kevlar Timing Belt, Balance Shaft Delete,
Head: 43 cc Hyundai Small Combustion Chamber Head - 3-Angle Job / Head deck / Media Blast & Hot Tank & All Plugs Replaced w/ Brass Fittings by TW Automotive & Machine. Head Rounded to flow 1G Intake Manifold,, Delta HKS 272 Regrind Cams, Kiggly Beehive Springs / Titanium Retainer, Kiggly HLA, Hyundai OEM Valves, Viton Valve Stem Seals.
- Mods-EMS & Logging
- ECMlink V3, AEM UEGO Wideband, AEM 5 Bar MAP Sensor, GM IAT,
- Mods-Drivetrain
- Race shimmed gearbox, TMZ Quarter Master 7.25" HD Gear-Drive Street Clutch Assembly w/ Race Friction Discs, TMZ 4-Spider Center Differential, AutoZone Font Axles,
- Mods-Handling
- STM ABS Delete. Ebay Front & Rear Strut Braces, Prothane Motor Mounts, Hawk Semi-metallic Pads ..
- Parts Wishlist
- Good tune, a less buggy idle, forward facing exhaust manifold.
- Background
- Always had an interest in turbo cars & the Eclipse that other people can't understand, except for you guys of course!
- 1/4 Mile E/T
- 12.100
- 1/4 Mile MPH
- 121.000
- 1/8 Mile E/T
- 13.000
- 1/8 Mile MPH
- 67.700
- 60' Time
- 9.999
- Dyno TQ
- 373.0 lb/ft
