Please Support Rix Racing
Street Build Tiki's 1998 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
SlowBoy/Kinetic Intercooler
3" SS Intercooler Piping
2G Intake Manifold
SlowBoy mbc
Expert Wire Tuck
FP 4" Intake pipe
FP Race Exhaust Manifold
Tial QR Bov
Fluidampr Harmonic Balancer
HKS clear timing cover
Fluidyne Aluminum radiator
Ford Taurus 4k cfm fan
APEX'i Power Intake Filter Kit
*Apexi n1* 3" turboback exhaust
Holset HX35 8 blade 56mm inducer
BEP .55 Bolt on Housing
Punishment Racing 02 Housing Recirculated
Tial MVS 38mm external WG
GReddy Radiator Hoses
1G TB
Cruise Control delete cable
EGR, Charcoal can, Evap Purge delete
Free FIAV block/disable (no more coolant flowing though the throttle body, and more importantly no more idle surge/bounce)
Walbro 450lph HP fuel Pump Rewired
FIC 1150cc Injectors
1g Fuel Rail
Buschur Racing (SX Racing/Edelbrock) Bolt-on AFPR
-12AN oil drain setup via 3/4" pipe fittings
-4AN stainless Feed (OFH) (RTM)
Restrictor 0.060
Mods-Engine
*6-bolt swap* (Forged ~6k miles)
2g Head '91 Talon Block
NGK BPR7ES Iridiums gapped to .023-024
NGK Spark Plug Wires
Skunk2 Adjustable Cam Gears
FP4R Cams with minimum 0.150+" piston to valve clearance
FP Dual Valve Springs and Titanium Retainers
1990 Oil Filter Housing with B&M Oil Cooler
ITM 3g Lifters
Cometic mls headgasket
Kiggly HLA Pressure Regulator
ACL Tri-Metal H series bearings Rod/Mains with 0.0025" oil clearance
MANLEY 9:1 Compression Forged Pistons 0.020" over with 0.100" valve relief fly cut
.022 and .028 compression ring gap
MANLEY Forged H-Beam Rods with ARP 2000 rod bolts
ARP 12mm Headstuds STD
Straight Cut Oil Pump Gears
Balance Shaft elimination kit OEM Mirage 1.6 parts and 90 degree out bearings
Mild OFH relief port
Mods-EMS & Logging
Innovate MTX-L WB 02
ProSport oil pressure gauge (cig lighter location)
Glowshift triple gauge pillar, 7 tinted series: top to bottom: BOOST/Volt/Coolant
*EcuFlash and Ceddymods*
Evoscan
Mods-Drivetrain
96 TRE Stage 2 with EVO3 5th Gear
Southbend DXD-B SS-X stage 4 Clutch Kit
2700Lb PP and 4 Puck sprung Disk
*B&M Short Shifter*
Sparco Racing Shifter Boot
Greddy Shift Knob and Evo X shift knob
95-96 Transfer Case
FEAL 441 Coilovers
Brake Performance Slotted Front rotors
ROTA 17" Wheels
VIS Carbon Fiber Hood
VIS Carbon Hatch
NRG Short hub and 2.0 Quick release
NRG carbon steering wheel
Parts Wishlist
Installed VENOM Smim....fits like ASS
Sparco p310 wheel and seats; STRUT BARS; oil and radiator caps; and stuff; and EGT, Water TEMP.
Tiki2777
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
