Please Support Kiggly Racing
Street Build Tiki's 1995 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
Slowboy racing FMIC
JMFab Race SMIM (Billet runner/CNC Velocity Stacks/O-ringed flange)
Tial Bov
Borg Warner Billet s259 ETT turbo
BEP s200 .55 a/r hotside
FP intake with K&N filter
FP exhaust Manifold
EGR delete Charcoal canister delete
Buschur racing catback 3"
RRE 3" downpipe
RRE 3" testpipe
Weapon R coolant overflow
Weapon R catch can
MAGNECORE 10mm wire
NGK BR7ES
FIC 1600cc Injectors
Aeromotive AFPR and AN fittings
AN rail adapted to Stainless line from tank to rail (-6)
Aeromotive Fuel Filter
Walbro 255
Custom power steering Cooler
B&M Oil Cooler with stainless lines
Oil Filter relocation (Ford filter)
Fluidyne Radiator
Slim Fans
Mods-Engine
6 Bolt 2.0L bottom end
Mitsubishi diamond logo valve cover
Competition 5 angle valve job (6 bolt head)
Extensive port work
Manley valve springs and titanium retainers
SI std size Nitrided Valves
Brian Crower 280 cams
Gates timing belt
ARP head studs
ARP Main studs
Clevite rod and main bearings
Wiseco 8.8:1 pistons
Eagle H beam rods
OEM Mitsubishi crank
Topline oil pump with straight cut gears
Fluidampr harmonic dampner
Fel-Pro Composite HG
Mods-EMS & Logging
Apexi Grounding kit
Apexi Turbo Timer (pen)
ECMLink v3
GM MAF 3"
MTX-L Wideband
Pro sport oil pressure gauge
Dual A pillar pod:
Pro sport EGT gauge
Pro sport boost gauge
Engine fan override switch
Clutch switch bypass
Mods-Drivetrain
PTT Twin disk clutch (sintered bronze metallic clutch disc pack)
PTT aluminum flywheel
Izuzu slave cylinder
B&M short shifter
Greddy shift knob
Counterweight removed
'95 GSX vented rear rotors
Stainless lines
Brembo drilled and slotted rotors
EVO ENKEIs
KYB GR-2s
Aerocatch hood latches
VIS Carbon Fiber hood
Parts Wishlist
Possibly AC put back in .... :|
  • Like
Reactions: Mattjaye2198
Tiki2777
Comments
10
More in 2G DSM
Share this Vehicle
