Please Support Rix Racing
Street Build The Polish Rocket
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
GT35 Variant
Drivetrain
FWD
Build Type
  1. Street
- 3'' Custom intake w/ 4'' KN filter
- Custom 3'' straight pipe with a Apexi muffler
-ETS short route innercooler
-Turbo XS-H BOV
-Walbro 450 LPH E-85 pump
-FIC 2150cc Injectors
-Aeromotive fuel rail -06AN Steel lines from tank to rail
-Fuel Lab 5'' stainless fuel filter
-Areomotive Fuel Pressure Reg
-Hallman boost controller
-Old School PTE machined to squeeze in a 67/66 billet wheel with a bolt on dsm housing
-FP exhaust Manifold with Heat Blanket
-Stainless steel 02 housing w/ a tial wastegate and scream pipe
-JMF Race version intake manifold
-S90 74mm throttle body
-Mitshimoto radiator
-Flex-A-Lite Dual Fans
-STM oil cooler w/ a 6-Bolt oil filter housing
-08AN Oil catch setup with breather
Mods-Engine
(Head)
-Kelford 272s
-Super Tech Dual Springs and Titanium Retainers
-ITM revised lifters
-Kiggly HLA
-SuperTech +1mm oversized valves
-Cometic head gasket
-ARP Head/Exhuast/intake manifold studs
-Poly mounts all around
(Block)
-1990 6-bolt block .030 over
-9:5:1 weisco pistons
-Eagle Rods
-Eagle crank
-Arp hardware/mains
-ACL bearings
-Balance shaft removed
Mods-EMS & Logging
-Dsmlink v3 with speed density
-AEM wide band
-Auto meter boost/Oil pressure/Water temp gauges
-GM E-85 content sensor
Mods-Drivetrain
-Act Xtreme clutch kit
-Street lite flywheel
-Stiff bushings
-Stock ride height.
-RTM Sway bars front and rear
-EVO 9 Brembos front and rear.
-EVO 8 Rims
Parts Wishlist
Suspension set up geared towards street and light drag use for weekends.
Paint job
Background
I found the car in Ft. Worth FL, it came from the Tampa area where a 67 year old retired teacher bought the car in 1997. She put 70,000 miles on the car before it was left outside a few years under half cover. I ended up getting a bone stock gst for $2,800 Cash. I'm in the process of building a six bolt block to go with a 2g head to have a end goal of 500+ Hp stay tuned!
Dyno HP
361 whp
362 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
STP Motorsports
Dyno Session Details
25 psi on e-85
GoCanes777
Rating
5.00 star(s) 3 ratings
More in 2G DSM
Share this Vehicle
