- Ownership Status
- No Longer Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- big 16g (01450)
blanketed evo 3 exhaust manifold
shielded evo1 o2 housing
heatwrapped megan racing downpipe
custom 3" exhaust back to magnaflow straight-through
innovate mtx-l
3" alum intake with 8" k&n filter
gm 3bar map & iat
acdelco '97 saturn alt with rewire and chassis ground overkill
fuelab afpr
fic 750
rewired walbro 255 w/ -6AN tank to rail to afpr
-4AN 0.070" restricted ss turbo oil feed from head
ngk 7mm wires
ngk br7es @0.028"
mitsu BCS w/ ecmlink bbg @21psi
tial bv50
prothane full poly mounts (modified)
custom shortroute i/c with ets street core
custom baffled ebay catch can
powerade overflow
custom hpwt-dh00 tails (282x 7-segments per side) w/ bluetooth enabled arduino-based microcontroller
- Mods-Engine
- king xp main bearings
clevite 77 aluminum rod bearings
engnbldr ss valves
3g lifters
bc springs & titanium retainers
supertech bronze exhaust valve guides
supertech i/e valve seals
balanced cut crank
- Mods-EMS & Logging
- 1995 ecu
ecmlink on speed density
- Mods-Drivetrain
- fidanza 3.2 pp
fidanza 4 puck sprung kevlar clutch
fidanza 8lb aluminum flywheel
- Mods-Handling
- wheels: unknown 5-spoke 17x7.5 ET40
front susp: kyb agx & gc coilovers w. 225/45/17 nt555
rear susp: kyb agx & some yellow springs out back w. 215/45/17 neogen
- Background
- purchased in 12/2008 from an auto insurance auction. rebuilt in 2012ish. upgraded a little bit every year or so.
