- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Galant GSX
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Autocross
- Mods-Bolt-on
- Evo 8 maf, 950cc fic's, ETS race intercooler and piping, manual boost, 1g Bov mod, 2g mani and evo 3 o2 ported, small 16g 7cm housing. Gsc s1, cyclone intake, 3" turbo back
- Mods-Engine
- 6bolt, Eagle 94mm crank, eagle H-beam rods 22mm wrist, Manley 86mm 9.0:1 pistons. Balance shaft eliminated. 1mm over ss valves. Upgraded double valve springs. Titanium retainers.
- Mods-EMS & Logging
- eprom ecu. Lc-1 wb02, solenoid for bov and cyclone
- Mods-Drivetrain
- Dsm 4bolt rear. Dsm manual swap. Southbend Ss tz Kevlar clutch, 2300lb south bend pp,
- Mods-Handling
- ST rear sway bar, UR fender braces, ebay strut tower bars f&r, rear toe elim kit. Heim joint rear upper control arms. FWD 5lug knuckles. poly bushings. 1gb 2pot calipers. Ss lines. Cross drilled rotors. Evox rims.
- Parts Wishlist
- galant caster/camber plates
