Please Support RTM Racing
talondave's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Drag Race
Holset HX40pro 6 blade with BEP T3/ .70 ar 3" V-band turbine housing, T3 ERL stainless cast Manifold, Tial MV-S 38mm Vband Wastegate, FIC 1600cc Injectors, ETS 10.5" x 5" thick race intercooler, Curt Brown Spec 2g JMF Drag Intake manifold, JMF oil catch can, 3gal fuel cell, n/t ported throttle body with block off plate, Fuel lab AFPR, Fuel Lab "818" inline fuel filter, 6-an SS fuel line (feed and return), jmf rear bumper defusers, custom 4" intake, 4" K&N filter, Magnus heat bearrier gasket, Prothane Motor Mounts, n/t ofh, Tial Q 50mm bov, 3" side exit exhaust, Skunk2 Racing Cam Gears, greddy timing belt, fluidyne radiator with two slim fans, dual inline walbro 255lph fuel pumps, jayracing alternator relocation kit, Frontline fab tube front-end, Seibon oem style CF hood, ATI balancer!
Mods-Engine
Kelford 280/276 Cams, Magnus Head Studs, Fully built Darkside 2g head, with copper o-rings, 1mm Oversized SS valves, five angle valve job, Arp main studs, ACL tri metal race bearings (main and rod), mitsu mls head gasket, 6bolt block, BEK, OEM oil pump 90 straight cut gears, wiseco 1400hd 10:5-1 pistons, manley turbo tuff I beam rods with 22mm pins, Supertech dual valve springs, Ti retainers and locators, Supertech valve seals, Kiggly HLA pressure regulator, kiggly girdle, half filled block
Mods-EMS & Logging
ECM Tuning V3, AEM Wideband, custom gauge cluster, with Autometer tach, Autometer speedo, Autometer Boost , Autometer coolant temp, Autometer Oil press, SD GM IAT, GM-style 4-bar map, custom build engine harness, and fuse box, 2g speed sensor.
Mods-Drivetrain
PPG Shep Dogbox trans, PTT twindisc clutch, three speed Scatter shield, DSS HD driveshaft, upgraded 300m Tcase, ARP extended wheel studs, DSS pro series rear axles.
Custom valved D2 coilovers, Wilwood 4 piston calipers with scalloped rotors, 15" Motegi Traklites, wrapped in 26/8.5-15 Mickey Thomson ET dragslicks, 12 point chromoly roll cage with chute mount, stroud parachute, cnc staging brake.
1/8 Mile E/T
5.549
1/8 Mile MPH
129.34
Timeslip Details
Track Name : Bradenton Motorsports Park
Nitrous : No
Fuel Used :
Vehicle Weight : 2397
Tires : DOT Slicks
Altitude : 59 ft
Sponsored Car : Rix Racing, JusTurbos, Dr. Fab
talondave
More in 1G DSM
Share this Vehicle
