1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support JNZ Tuning
Street Build Street/Mountain hill climb 1990 Eagle Talon TSI
Year:
1990
Model/Trim:
Eagle Talon TSi AWD
  • Ownership Status:
    I own it
    Turbo Type:
    14b
    Drivetrain:
    AWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    Aluminum Mishimoto radiator. Non-Cruise Control throttle cable.
    Mods-Engine:
    Balance shaft delete. Boost pill delete. Hacked MAF.
    Mods-EMS & Logging:
    Palm Pilot data logger. Auto-Meter boost gauge. Auto-Meter exhaust temp gauge.
    Mods-Handling:
    Front stainless steel braided lines. '93 upgraded front calipers. stoptech slotted rotors (Front). EBC red brake pads (Front). KYB GR2 shocks. polyurethane sway bar bushings. Front strut tower bracing.
    Background:
    I purchased this car from a local DSM Tuner TedSpec who had bought it from the original owner who happened to be an original member of the BA.DSM group in the Bay Area. I've since gone through and mostly been doing maintenance and fixing small problems such as a boost leak, a bloated radiator hose, and the worlds sloppiest shifter. I hope to build the car into a mountain racer, AWD manual 400Hp street car.
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
