Showcar Build Spyder 2.4l 4g64 DOHC 4g63 Stroker Turbo Swap Fully Built Tucked Engine Bay Street/Show Vert
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder GST
Turbo Type
20g
Drivetrain
FWD
Build Type
  1. Showcar
Chrome intake with K&N filter
Large FMIC and Greddy BOV Open Dump
Apexi 2.5" down and full 3" catless exhaust
EGR delete
SS clutch line master to slave
SS turbo oil feed line with .70 restrictor
SS turbo drain line
STM block PCV breather adapter + recirculated catch can valve cover SS hoses
Walbro 255 rewired
Silicone coolant hoses, Aluminum radiator and overflow, slim line fans
-6an from filter to rail and to AFPR
Hallman manual boost controller
Stainless Tubular exhaust manifold, ported stainless o2 housing
FIC 850cc injectors
70mm Throttle body with FIAV and ISC delete, intake ported to match
OBX intake manifold gasket thermal spacer
Tons of dress up
Polk dB 6.5" components up front and 6x9" 3 way in rear Marine grade speakers powered by their own amp.
Mods-Engine
DOHC 4g63 head on 4g64 2.4 block
Wiseco pistons for 4g64 dohc stroker 9:1 ratio
Eagle H beam forged rods /w Arp
Arp head studs
MLS head gasket
King bearings
Fully machined and balanced - Thanks Small World of Eugene Oregon
Brian Crower valves springs and titanium retainers
Running strong LLC one piece undercut SS 1mm OS high performance valves
Head oil port mod
OFH port
BS delete
Crank ball journals cleaned replaced
3g lifters
Kevlar belts
Mods-EMS & Logging
ECU+
GM lt1 3" MAF
PLX Gen 4 Wideband and DM-6 gauge
PLX Oil pressure
PLX Boost pressure with 3 bar map logging
Mods-Drivetrain
Manual swap, New master and slave cyl, new axles, XTD lightweight flywheel, ARP flywheel bolts. Act2100 PP and street disk, spec clutch fork.
Short shift kit, solid shifter base bushings, solid cable bushings at trans
All new stock bushings, control arms, tie rods and joints upfront. Adding rear sway bar and rear disk brakes for the Spyder.
Poly motor mounts
Parts Wishlist
Headlights! New drop top, body kit, exterior paint, taillights (This completes the body)
Shocks/Springs, Adj cam gears, Cams... ect...
Racing seats, roll bar?
In that order about
Background
This is my friends 1997 Spyder GS. I work as a private mechanic and since my friend got the car in fall 2013 he has wanted to upgrade it. Through determination he saved enough to do just that, starting with the engine. It started to have a lot of problems, mostly auto transmission related, but with 230k miles on the engine it has run its course.
The plan was set into action when a 1995 gst manual was purchased with a blown headgasket.
This car was completely stripped, parts needed kept and not needed sold. Ended up being a great deal.
We are starting with a fully built block and head with only light outer mods. Stock cams, tuning and fuel delivery for now. First upgrade after the car is running will be EPROM computer and ECM link, then fuel delivery, then turbo. Do it right I say.
Then he will need to go AWD to handle the power ofc...
Project officially started with planning and purchases March 2014, engine pulled July 5th, car is hoped to be running by Aug 2014.
*Very close Sept 21st... Lots going on in everyone's life amazing car is getting worked on at all but we are pushing through it.*
******NOV 12th 2014 AND Literally a few hoses away!******
See all the pre planning and parts car here.
http://www.dsmtuners.com/threads/introduction-and-precurser-to-spyder-4g64-dohc-swap-and-turbo-build-with-questions.477110/#post-153444168
****** Car was running in Dec, but a few delays and now Jan 20th 2015 it is on the road!*****
****** May 25 2015, Oil pressure sensor cracked and friend kept driving it even seeing oil press dropping. Had to cut the crank .25mm and redo bottom end.*****
****** July 26 2015, engine rebuilt and dropped in, bay painted . 20g turbo ecu+ and lots of upgrades *******
****** Aug 20 2015, screwed on 2 turbos, now running a used something 16g, car runs again. ******
****Oct 1st 2015 After buying a new 20g from Justin it is running good again finally.***
****Dec 1st 2016 Car has been down for a few months, only 3000 mi on the XTD 6 puck and it took a crap. Mostly due to weak pressure plate and failing/unadjustable master cyl. Has new act street disk and new OEM master and slave, back to running.*****
darknezz7
Comments
17
Rating
5.00 star(s) 5 ratings
More in 2G DSM
Share this Vehicle
