Please Support RTM Racing
Please Support Rix Racing
Spdfreak's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT42 Variant
Drivetrain
AWD
Build Type
  1. Drag Race
garett gt42 jb ,shearer fab top mount manifold,tial 44mm wastegate,4" exh,ets 5" fmic ,magnus intake manifold,tial bov, coil on plug,aeromotive pro series fuel pump and regulator,1600cc fuel injectors, victory performance fuel rail
Mods-Engine
6 bolt 2.0l block,arp l19 headstuds,kevlar timing belt,balance shaft eliminator kit, custom ross pistons , aluminum rods,hks adj cam gears,90mm throttlebody,bc cams,cometic hg ported and polished head, supertech dual valvesprings, 1mm over int/exh valves titainium retainers
Mods-EMS & Logging
aem ems, boost gauge, oil pressure, rpm, aem wide band ,coolant temp,msd dis2
Mods-Drivetrain
shep stg4 trans, drive shaft shop 3" driveshaft, dss stg4 rear axles, 300m transfer case stock front axles,three speed scatter shield,quatermaster 7.25 v-drive clutch
power slot rotors hawk pads,goodridge stainless steel brake lines,skunk2 coil overs, tokico illumina struts,10point chromoly roll cage,parachute mount,window net, volk te37 16x8 +42 offset, hoosier qtp slicks 26x9.5x16
Parts Wishlist
front tubular k member (99gst_racer) lol
Background
I got this car when I was in high school, best thing ever at the height of import racing in my area. I planned on building for drag racing only.
1/8 Mile E/T
10.050
1/8 Mile MPH
83.500
444.0 lb/ft
Videos
Two step teaser
Quick video of testing the two step
gt42 turbo
aem ems
Spdfreak
More in 2G DSM
Share this Vehicle
