Drag Race Build SonySlave's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT35 Variant
Automatic
Build Type
  1. Drag Race
BorgWarner S300SX FMW 62mm 1.10A/R TS T4 | F5 Racing Top Mount TS T4 Manifold | Tial 44 Wastegates | Dynarc Fabrication Hood-Exit Exhaust | Evo 3 Intake Manifold | 63mm NT Throttle Body | Kinetic FMIC w/ Custom Piping | Tial Q BOV | E98 Fuel | FIC 2150cc Injectors | FIC Fuel Rail | JMF Anodized Fuel Cell | Magnafuel 4303 Fuel Pump | Aeromotive AFPR | -8AN Fuel Feed/Return Lines | Meziere Electric Water Pump | -12AN Coolant Hoses | TurboStart 16V Battery | Remy Battery Box | Moroso Killswitch | English Racing Catch Can w/ Hal Landry Vented Oil Cap | FCSRace Engine Diaper | VIS Carbon Fiber Hood
Mods-Engine
Turbo4.com 'Short Long Rod' Half-Filled 2.2L w/ 2G Head - Eagle Crank (94mm) | Manley Platinum Stroker Pistons (10:1/22mm Pin) | R&R Steel Rods (153mm) | ACL Main/Rod Bearings | Kiggly Main Brace | ARP Main Studs | ARP L19 Head Studs | Felpro Permatorque 1153-1 MLS Headgasket | Engnbldr STD-size Stainless Valves | GSC S2 Cams | Kiggly Beehive Valve Springs/Retainers | 3G Lifters | Kiggly HLA Restrictor | Fluidampr Crank Pulley
Mods-EMS & Logging
Haltech Sport 1000 ECU | Racepak IQ3 Race Dash | AEM 5-bar MAP Sensor | Haltech Electronic Boost Solenoid | Haltech IAT | Haltech CAN Wideband | Haltech TC4 Individual EGT Kit | Haltech HPI4 Ignition Box | SparkTech 300M COP
Mods-Drivetrain
Metro Automatic Trans w/ Welded Center Diff | PI 1G Billet Torque Converter | Kiggly SFI Flexplate | English Racing 300M Transfer Case | 3.5" Aluminum Driveshaft | Hayden Trans Cooler | B&M Pro Ratchet Shifter | ForcedFour Shift Box Color | Jeff Bush T-Case Brace | TunersNation Billet Driveshaft Bushings | Stainless Brake Lines
Dynarc Fabrication 10-pt Mild Steel Roll Cage | True Street Tuning & Fab Chromoly Mustache Bar | 99GSTRacer Chromoly Front Crossmember | 15x7" Drag DR-17 Wheels | 235/60-15 M&H Street/Strip DOT Slicks | Eibach Pro-Kit Springs | KYB AGX Struts | Energy Suspension Polyurethane Subframe/Control Arm Bushings | Rear Active Toe Eliminator Kit | Front Strut Bar
Parts Wishlist
Straight-Cut Auto Transfer Gears | 10pt Chromoly Roll Cage | 26" M&H Slicks | Chromoly Tube Front Subframe | The Brake Man Drag Brake Setup | English Racing Chromoly Steering Column | Powerlite Lithium 16V Battery | RWD 4G63 Toyota Starlet
1/8 Mile E/T
6.238
1/8 Mile MPH
112.53
Timeslip Video Link
Watch Video
Timeslip Photo Link
Timeslip Details
Track Name: The New Capitol Raceway
Turbo: BorgWarner S300SX FMW 62mm
Nitrous: No
Fuel Used: E98
Vehicle Weight: 2825
Tires: M&H 235/60-15 DOT Bias-Ply Slicks
Sponsored Car: No
SonySlave
Comments
Rating
5.00 star(s) 4 ratings
More in 1G DSM
Share this Vehicle
