- Ownership Status
- No Longer Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- EvoIII exhaust manifold, billet compressor td06 20g turbo, punishment racing o2 housing, 3" stainless straight pipe, fp intake pipe, vrsf fmic, hallman mbc, avid racing poly engine and trans mounts, tial 38mm wastegate, walbro 255, fuelab 818 filter, fic 1050cc injectors, aeromotive afpr, jay racing alternator relocation, fluidyne aluminum radiator
- Mods-Engine
- 6 bolt block .020 over, Eagle h beam rods, wiseco 8.3:1 pistons, acl race bearings, acl oil pump, arp head studs, 7 bolt head, 3g lifters, delta 272 cams, aem cam gears
- Mods-EMS & Logging
- dsmlink v3 full, speed density conversion, gm iat and omni 4 bar map, aem boost, oil pressure and wideband gauges
- Mods-Drivetrain
- galant vr4 transmission, act 2100 pressure plate, act 6 puck unsprung disc, act streetlite flywheel, 91' shifter converted to solid bushings, autozone special axles (lifetime waranty ftw)
- Mods-Handling
- d2 rs coilovers, front and rear strut bars, 6 piston wilwood big brake kit, 17x9 drag dr31's
