- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- jmf race smim
fp exhaust manifold
FP red
direct port methanol injection, 320ml/min nozzle per runner
bluemax 1350cc injectors
FIC easytune injector driver
drilled out fuel siphon
walbro 465 lph fuel pump
8an fuel line from tank to fuel rail, aeromotive fuel filter
- Mods-Engine
- manley h-beams
manley crank
wiseco 1400hd pistons 9.7:1
GSC S1 cams
fidenza cam gears
kiggly HLA
head is ported and runners are knife edged
supertech valves
dual valvesprings
GSC turned balance shaft
ARP mains and headstuds
MLS headgasket
oil pressure relief valve ported
ACL race bearings, main and rod
- Mods-EMS & Logging
- ECMlink
AEM wideband
AEM 5-bar map
GM IAT
- Mods-Drivetrain
- fidenza flywheel
ACT street disc with 2600lb pressure plate
- Mods-Handling
- stainless steel brake lines
