- Ownership Status
- Currently Own
- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Drag Race
- Mods-Bolt-on
- Jay racing alternator relocation, rear mounted battery, FP Black turbo with custom forward facing exhaust manifold, customer charge piping, 1G Turbo throttle body, custom side exit exhaust, Tial 38mm MVS wastegate dumped to atmosphere, custom air intake, JMF race manifold modified for dual fuel rail, magnus fuel rails, 8 FIC2150 injectors, Magnafuel 4103 fuel pump and Magnafuel AFPR (-10 feed, -8 return) with Magnafuel filters, Summit 15 gal fuel cell, Civic half radiator, B&M trans and engine oil coolers, Ultrashield aluminum drag seat, Sweet Mfg quick release steering wheel, , Simpson parachute, DJ Safety harness, Stroud window net, custom chromoly cage, ABC fire extinguisher, R&R wire harnesses, customer oil catch can and crankcase vent, non-cruise throttle cable
- Mods-Engine
- 6-bolt NA wet block, factory crank, Wiseco 1400HD 10.0:1 pistons, Custom BME aluminum rods, Kiggly main girdle, ARP main studs, ARP head studs, HKS stopper head gasket, 1G cylinder head with custom Force Engineering porting, factory intake valves, Ferrea +1mm exhaust valves, Kiggly beehive springs shimmed, Delta K272 cams, Kiggly HLA with 1G lifters, Gates timing belt
- Mods-EMS & Logging
- Haltech Elite 550, Haltech WBA-1 wideband controller, Haltech CAN hub, Haltech/Racepak IQ3 Display Dash, Leash electronics relay/power board, LS3 ignition coils, AEM 5-bar MAP, GM IAT, MAC 3-port EBC, DSM TPS, green top CAS modified for use with Kiggly 12 tooth crank trigger
- Mods-Drivetrain
- Factory axles, rear differential, and transfer case. JNZ rebuilt driveshaft, Kiggly trans adapter kit, "The Dragon" Precision torque converter, 2G trans, Kiggly 5-pack front clutch, welded center diff, translab shift kit, modified valve body for ratchet shifting and Haltech shifting, modified low/rev brake clutch assembly
- Mods-Handling
- Stop-tech rotors, organic pads, factory 1GB calipers, VW vacuum pump, KSport coilovers, custom rear springs, ingalls rear upper control arms, manual steering rack, Eagle Alloy aluminum wheels, 26x9.5x16 Hoosier QTPs
- Parts Wishlist
- Switching to mechanical fuel pump and air-to-water intercooler for 2020 season.
- Background
- Picked this up to build a consistent track-only drag car to decimate the local competition and put up a good fight at the large events!
- 1/4 Mile E/T
- 10.516
- 1/4 Mile MPH
- 133.42
- 1/8 Mile E/T
- 6.786
- 1/8 Mile MPH
- 103.44
- 60' Time
- 1.495
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Q2 pass at The Shootout 2019. Hit rev limiter twice. 25psi, methanol, no nitrous, Hoosier QTPs, Summit Motorsports Park in Norwalk, OH
- Dyno HP
- 470 whp
- Dyno TQ
- 370 lb/ft
- Dyno Type
- Mustang Dyno
- Dyno Shop Name
- Buschur Racing, OH
- Dyno Session Details
- 2019 The Shootout dyno day
