Street Build Project 2g GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
Forced Performance Black ported and coated
Forced Performance exhaust manifold ported and coated
Punishment Racing O2 housing with
TiAL external WG 38mm (15lb spring)
Hallman MBC
Magnus SMIM
S90 70mm TB/FIAV bypass
Fidanza "limited edition" black cam gears
SRS turbo back exhaust
Fuel Injector clinic 1100 hi-z Injectors
Magnus fuel rail
Walbro 450/Aeromotive hybrid FPR/Radium FP gauge
Gates blue timing belt
/bkr7 plugs
Jay Racing alt. relocation kit
GM/Saturn (160amp, 1.9" pulley) Alt.
Mishimoto Radiator
Mishimoto 180* Thurmo., Rad. cap & magnetic oil drain plug
STM 3" Intake Kit
Punishment Racing FMIC
Sparco r100 seats & Sparco 2g Base
NRG steering wheel/pedals/shift knob
Tial BOV
Aluminum drivers side door handle
JM Fab small battery kit w/Braille battery
Oil catch can
Ralco RZ short throw shifter kit
Mods-Engine
Forged 2.3 stroker
Pre-95 7-bolt block - SUPER RARE (block cast in 1994)
JE Forged "Asymmetrical FSR" pistons -
Forged "Race Series" Manley crank -
Skunk2 "Alpha Series" H-beam rods -
Mach V/Concept Racing (MBCAD) kit -
Built cylinder head/GSC valves/Supertech springs/titanium retainers/ Viton seals -
ATI Super Damper -
Brian Crower 272/272 camshafts -
Kiggly HLA pressure regulator -
ARP head/girdle/rod/cam -
OEM stub-shaft BSE -
OEM straight cut oil pump gears -
ACL/Orbit oil pump -
Evo III OFH/13 row oil cooler -
Mods-EMS & Logging
ECMLink v3
Speed Density kit
HKS turbo timer w/plug and play harness
AEM X-Series Wideband UEGO AFR Gauge
Blitz Mirror Drive Boost Gauge
Blitz Mirror Drive Oil Pressure Gauge
Blitz Mirror Drive Water Temp Gauge
Mods-Drivetrain
ACT 2600 Clutch Kit
Fidanza lightweight/aluminum flywheel
SS clutch line
ExtremePSI throttle cable
Eibach Pro Kit
Koni adjustable shocks
Tein pillow ball mounts
Enkei Imola 17's
245/40RZR17 Khumo Ecsta PS31
Clayfmbtwn4124
More in 2G DSM
Share this Vehicle
