Please Support Rix Racing
Street Build El Mito
Ownership Status
Currently Own
Mitsubishi Eclipse GST
Turbo Type
HX35
Drivetrain
FWD
Build Type
  1. Street
Intake: FMIC w/ custom 2.5" piping and TB elbow, Tial Q Bov, 1g throttle body, evo 3 intake manifold with thermal gasket, snow performance water/meth kit.
Exhaust: custom t3 top mount manifold, twin scroll 12cm hx35, 38mm turboxs wastegate, 3" custom SS downpipe ceramic-coated, apexi N1 catback exhaust (catless).
Fuel: Custom high flow fuel rail, 515 Fuelab FPR, walbro 400lph, Fuelab tank to rail 6an kit w/ fuelab filter, RC750cc injectors.
Misc: EGR delete, taboos vacuum delete, battery relocated, tucked radiator, C.O.P w/ dynatek ARC-2, Cruise control delete, A.C. delete, alternator relocated full wire tuck, FIAV delete, catch can w/ 10an valve cover fittings.
Mods-Engine
High mileage stock 7Bolt engine!!! Balance shaft delete, external oil cooler.
Mods-EMS & Logging
DSMLink V3 full on SD, Innovate MTX-L wideband, EVO prosport boost gauge, Innovate MTX-D oil pressure/temp gauge, cheap volt gauge, ecmlink boost by gear, HKS turbo timer, custom pc head-unit for logging and tuning.
Mods-Drivetrain
SS line from master to slave, OEM shifter, stage 3 competition clutch, fidanza aluminum flywheel, solid shifter cable bushings
DBA4000 t3 rotors, polyurethane motor mounts, stoptech ceramic pads, SS brake lines, GSX brake swap, unknown 17" wheels, front, rear and lower rear strut bars, Tein Flex Z coilovers, tubular upper control arms with camber kit, 225x45 tires
Parts Wishlist
AWD swap
Background
Owned since Oct 2011, completely stock, car was involved in a minor accident.
Videos
eclipsyco
Comments
More in 2G DSM
More from eclipsyco
Share this Vehicle
