1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Drag Race Build My talon build!
Year:
1990
Model/Trim:
Eagle Talon TSi AWD
  • Ownership Status:
    I own it
    Drivetrain:
    AWD
    Transmission Type:
    Automatic
    Build Type:
    • Drag Race
    Mods-Bolt-on:
    HX40 Pro With 67mm Billet wheel With .82 A/R T3 Hotside
    ETS 10.5 Race intercooler 3in intercooler piping
    Tial 50mm Bov
    Punishment Racing T3 Manifold Open scroll
    Tial 38mm Wastegate
    JMF Billet Intake manifold
    S90 70mm Throttle body
    Custom 3.5in Full exhaust with downpipe in stock Location
    Fuel Lab FPR
    Dynatech ARC 2 with 300M Coil on plug
    MagnaFuel 4303 With Magnafuel Filter and 8an Feed 6an return with Sumped stock tank
    Dry 75 Shot NOS
    Mods-Engine:
    1g Head port and polish,
    1mm GSC Valves
    Kiggly High Pressure springs and retainers
    280/280 GSC S2 cams
    Kiggly HLA
    FIC 2150 Injectors
    Fuel Lab Fuel rail
    R&R 156mm Solid Aluminum Rods L19 Bolts
    Wiseco HD 10.5.1 Stroker pistons
    `1/2 Fill Block
    ARP Mains
    Kiggly Girdle
    L19 Head studs
    Stainless Steel Orings
    OEM MLS Head gasket
    Balanced Stock crank
    Straight Cut OEM oil pump
    GSC Race Balance Shaft
    Balanced OEM Balancer
    Mods-EMS & Logging:
    ECMLINK V3 Full
    Autometer Trans Temp
    Autometer Fuel pressure
    Autometer Boost
    Autometer Coolent Temp
    Innovative LC2 Wideband
    Mods-Drivetrain:
    Sinister Speed 8" Converter
    Rebuild Auto
    Kiggly Forward Clutches
    Kiggly End clutch pack
    Shift Kit
    Welded Center diff
    Force 4 Shift box
    Mods-Handling:
    Megan 32 adjustable Coil overs
    Polly Suspension mounts
    Centerline Forged 15in Rims
    Hoosier QTP 26/9.6/15
    ARP Extened wheel Studs
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
