My little 1g
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
HX40
Drivetrain
AWD
Build Type
  1. Street
FP manifold with Tial 38mm external wastegate
Holset hx40 turbo
VRSF Intercooler Piping
VRSF Front mount intercooler
turbo back Megan racing exhaust
Coil on Plug system
Speed density
AEM X series Wideband AFR
AEM X series Oil pressure
AEM X series Vacuum Gauge
Greddy BOV
Non Cruise control Cable
FIC 1800cc injectors
AEM 340lph fuel pump
EGR Blockoff
Prothane Motor Mounts
DSS 3” driveshaft
Bushar fpr
Fuel Lab fuel filter
Dynatek ARC 2 Spark Box
Magnus SMIM
S90 TB 74mm
FIAV blockoff
Mods-Engine
4G63 6 bolt Non turbo Block
Balance shaft delete
ACL tri metal main and rod bearings
Eagle H Beam rods
Wiseco 1400HD pistons 10.6:1 comp ratio
Kelford 272/272 lowlift cams
GSC high rev behive valve springs and retainers
Oil Gallery mod
Ported 90 ofh
Copper Freeze Plugs
ARP 2000 rod bolts
ARP L19 Head studs
Cometic MLS Head Gasket 86mm
Mods-EMS & Logging
ECM Link V3 full
Mods-Drivetrain
ACT Sprung 6 puck Clutch
ACT lightweight flywheel
KYB AGX shocks / Eibach springs
Motegi Trak Lites 17x7
Parts Wishlist
Stage 5 Dogbox trans, Big Brake Kit, better 6 bolt intake manifold, wheel and tire combo
Background
Planning on having a good looking car that if you come across it on the freeway in your little Mustang or GTR you might feel confident in your ability to beat it until all you seeing is my glorious little 1g taillights fading into the distance.
Clayton Schultzn
More in 1G DSM
Share this Vehicle
