- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 14b
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- 190 lph fuel pump, custom spark plug cover,14b turbo with an turbo lines, hood strut conversion.
- Mods-Engine
- basic stock motor for now. upgraded larger oil cooler with 8 AN pro classic lines.
- Mods-EMS & Logging
- oil temp gauge, water temp gauge, boost gauge, dsmlink full version 3
- Mods-Drivetrain
- fidanza short throw shifter, 2 piece custom made drive shaft, torque solution solid carrier bearing bushings, skate board shifter bushing mod, custom made shifter base bushings, stainless clutch line, 4 bolt rear end swap, "05-"06 Outlander front big brake upgrade.
- Mods-Handling
- gab strut tower braces, rear decla rotors drilled and slotted, energy suspension urethane sub frame mounts, ST suspension rear stabilizer bar with urethane mounts. Volk racing: active rear toe eliminator, Volk racing: tubular crossmember, Volk racing: rear lower adjustable control arms, 3SX red brake line kit designed for a 92 fwd 3000GT SL, power steering pump and lines deleted, de-powered rack lines plugged with brass plugs, custom electric assisted steering setup.AGX adjustable damping struts front and rear.
- Parts Wishlist
- real mhi big evo 3 16g.
evo injectors.
speed density
1gb engine wire harness.
carbon fiber roof
carbon fiber hatch
carbon fiber hood
- Background
- I basically saved this car from the crusher, I learned a lot from the car and did a lot of work on the car, I plan to over time build it into a drag car possibly or street/track car.
