mikEclipse99's Eclipse awd swapped
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Drag Race
PTE 6870 1.15 AR, KSR Performance custom forward facing twin scroll manifold, 2 tial 44mm MVR, tial Q 50mm BOV, aluminum half radiator, FFWD mechanical fuel pump bracket, Waterman fuel pump, ID 2200's, Aeromotive fuel pressure regulator, S90 74 mm throttle body
Mods-Engine
JE Buschur spec 10:1 pistons, Manley Turbo Tuff rods, 6 bolt block, 2g ported head, ARP L19 head studs, ARP main studs, ARP 625+ rod bolts, BSE, SCE Vulcan head gasket, Kiggly girdle GSC Billet S3 cams, Fidanza gears *RIP 7 bolt block 2008-2018*
Mods-EMS & Logging
dsmlink v3, Speed Density: AEM 5 bar MAP sensor, GM IAT sensor, AEM Wideband UEGO, AEM TRU-boost, and AEM oil pressure
Mods-Drivetrain
AWD swap, PPG 1-4 Dogbox built by Shep Trans, 300m output shaft, Boostin Performance Billet bearing housing, tubular rear subframe, tubular front subframe, Vamos Fab DS loop, Carbon drive shaft
Megan racing street series coilovers
1/8 Mile E/T
5.865
1/8 Mile MPH
131.43
Dyno HP
771 whp
613 lb/ft
Dyno Type
Mustang Dyno
Dyno Session Details
6870 48 psi e85
mikEclipse99
Comments
3
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
