Please Support Rix Racing
Street Build "Lucky" Sevens Talon
Ownership Status
No Longer Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
EVO 3 16G turbo
Custom O2 housing with external wastegate (Turbosmart Comp Gate 40mm)
Custom 2.5" aluminium intercooler piping
3.5" thick core FMIC
K/N stockbox air filter
Turbosmart Boost Tee controller
Samco rad. hoses
EVO 9 fuel pump + rewire
FIC High Z 1000cc injectors
AEM Fuel Pressure Regulator + custom line
Custom EGR block-off plate
2.5" downpipe
3" catback exhaust (2 resonators)
Front/Rear/Driver side polyurethane engine mounts
Mods-Engine
EVO 7 [8.8:1]CR pistons and rods
ACL Race Series conrod bearings
ACL AluGlide main bearings
Ajusa Fibermax Headgasket
Polished 2G head
1G lifters
G+H cams, 8.22mm lift
NGK "7"ES plugs (.0255" gap)
Mods-EMS & Logging
ECMLink V3 full + '95 EPROM 2G ECU
Innovate LC2 wideband O2 sensor and DB gauge
Standard boost gauge
GM 3Bar MAP sensor
GM IAT sensor (off a Jeep)
Running Speed Density
Mods-Drivetrain
Competition 2100 Clutch kit
Stock rear LSD
Poly shifter base bushings
Bearing'd shifter cables
KYB AGX shocks (off road height spec)
Dodge Stealth 17x8.5" swirly wheels
3000GT VR-4 4 piston calipers and discs (313mm)[with custom CAD brackets], front
Galant VR-4 284mm ventilated discs and calipers, rear
Parts Wishlist
Auto Trans, Twin scroll turbo
Background
My first turbo-AWD DSM. I'm the 2nd owner. Got her in very bad condition, but I was getting it blindly so it didn't matter. Went to a neighbour country to get her with a flatbed. Car had 26,000 miles on the clock. It had sat for 15 years without being driven and it took 3 months to get her in somewhat good shape. The long-term plan is a full restoration and then upgrading to a mild street build (~300 AWHP).
Reason for the Lucky 'Sevens' name is ironical. The VIN ends in "077777", a very unique number, full of sevens, but I had a lot of bad luck with the car in the beginning, hence the name.
As of November 2018, the engine has been taken out, a new block bought and the project is underway for building it up and installing a Big E16G.
UPDATE: First official start on the new rebuild was on March 12th, 2019. All went well!
12.17.2023 Update: Sold the car to a close friend of mine...
Kryndon
Comments
3
Rating
5.00 star(s) 5 ratings
More in 2G DSM
Share this Vehicle
