Please Support Rix Racing
Street Build LouieAWDTSi's AWD Turbo Spyder
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
GT35 Variant
Drivetrain
AWD
Automatic
Build Type
  1. Street
Garret gt35r turbo with 82 HTA compressor, Modified 3in. Megan dp Thermal CatBack, Punishment/CX Racing FMIC, NGR BOV, Rx4Speed 4 inch intake, Prothane Poly Motor Mounts, open o2 dump with Tial MVS 38mm w/g, t3 OBX Exhaust Manifold, JMF Street Intake Manifold, 1g NA Throttle Body, JMF oil catch can, Gamble garage coolant overflow, Aeromotive AFPR.
Mods-Engine
7-bolt head w/ Kiggly Beehive Valve Springs & Retainers, Topline Revised Lifters, HKS 272 Cams, ARP Head Studs, Fel Pro MLS Head Gasket.
2.3 stroker 6 bolt short block
.020 over bore -OEM Mitsu 2.4 crank -Oliver Rods w/Ross Pistons 8.8:1 -ARP hardware-ACL Race Bearings
Mods-EMS & Logging
Boost solenoid ran directly to ECMlink V3 Full w/ Speed Density, PTE 1,000cc injecters, rewired 255 Walbro pump, Innovative Wideband gauge, GlowShift Oil press, Water Temp, Trans Temp, and Boost/Vac Gauges, Greddy Turbo Timer, Light Weight 12v Battery Tender Battery.
Mods-Drivetrain
AWD Swap from a 95 Talon TSi AWD, Auto swapped a few years later, 2g trans with TransLab shift kit, Valve Body Adjustments, Kiggly 5 Friction Front Clutch Kit, Welded Center Diff, Viscous Coupler Eliminated, New Frictions/Seals, Kiggly Racing Flexplate, B&M Auto Trans cooler, Precision Industries Tq Converter
AWD Dual Piston Calipers, 3g brake booster Unknown Name Adjustable Coilovers
Parts Wishlist
Paint/Body work, e85 FlexFuel, Upgraded Brakes, ForcedFour Shift box, Paddle Shifters
Background
This is my 3rd DSM, always wanted a 2g and always liked convertibles. I missed the AWD too much so I went ahead with the swap. Goals, well built..clean.. 500awhp street spyder.
Videos
YouTube: LouieAWDTSi_
  • Like
Reactions: Puddlejumper
LouieAWDTSi
More in 2G DSM
Share this Vehicle
