- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Transmission Type
- Automatic
- Mods-Bolt-on
- SCM50BB Turbo // 3.5" Intake,Thermal Research SS 3" Exhaust // VRS SS 3" DP w/O2 Eliminator // SBR DSM Stage II Ported Manifold // 3" SS Hifow Cat // Magnecor 8.5mm Wires // NGK Plugs // Greddy Type RS BOV // Walbro 255hp // Denso 720cc injectors // Aeromotive AFPR // DSMLink V2 // PRofec E-01 // PLX Wideband O2 // IPT Trans with custom torque converter // Quaife LSD // IPT A/T Boost Controller // SBR FMIC // Trans Cooler // Fluidyne Radiator // 2 12" slimline fans // Prothane motor mounts // TCUGO wireless paddle shifter
- Mods-Engine
- New 7 bolt motor with 1G rods // 2G Pistons // elimated the balance shaft.
- Mods-Handling
- Ground Control Coilovers // Koni Sports // RM Racing Swaybars // KONIG 17's x 7.5" // TOYO Proxy4 215/45/17 // Front/Rear Strut Bars // Baer Track system 13" slot/drilled/zinc rotors // Baer Rear replacement slot/drilled/zinc rotors // Green Stuff Pads // Complete Prothane Bushing Kit // New Hubs & Axles
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 393.0 lb/ft
- Dyno Type
- DynoJet
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : PTE5031 BB
Boost : 26
