Please Support JNZ Tuning
Road Race Build John Freund's Time Attack 99 Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Road Course
- BW EFR 7670 .92 Internal Wastegate T4 Twin Scroll, wrapped in custom Inconel Heat shielding
- (REMOVED 8/2017) FP 3076 wrapped in a PTP Turbo Blanket, with FP cast O2 housing and Tial 44mm wastegate (recirculated), wrapped in DEI Titanium Exhaust Wrap
- Archer Fabrications custom T4 TwinScroll exhaust manifold
- (REMOVED 8/2017) FP Race Manifold with custom heat shield
- full 3" exhaust, no cat or mufflers/resonators
- Bell Intercoolers custom fmic
- 1150cc FIC injectors
- Custom Coil-On-Plug, self-designed. eliminates PTU and stock ignition coils. Coils provided by Spoolinup.
- (REMOVED 5/2019) HKS EVC 5 boost controller
- Cortex EBC Electronic Boost Controller
- (REMOVED 8/2017) NGR Type-S bov
- Boomba Racing 75mm Evo TB w/ EVO IX TPS
- (REMOVED 4/2019) Venom intake manifold, reflective tape wrapped, phenolic spacer
- Magnus Motorsports 2g Cast Intake Manifold
- Ron Davis Radiators custom dual-pass radiator, built-in oil cooler
- Custom FMIC/Radiator ducting (fully sealed)
- Custom Coolant Surge/Header Tank
- Custom Coolant Swirl Pot
- BPR 7es plugs gapped at .022"
- (REMOVED 2018) Apexi Power Intake air filter
- ITG Maxogen Air filter in custom airbox
- Deatschwerks DW300 in-tank pump
- 034 Motorsports Fuel Surge Tank with Bosch 044 in-tank pump.
- Aeromotive fuel pressure regulator at 43.5psi base
- Spoolinup prototype COP
- Odyssey PC680, relocated to behind Passenger Seat
- Custom alternator heat shield
- Starter heat shielding
- Custom 3" cold air intake to sealed/shielded airbox
- Optic Armor 1/4" Front Windshield, 1/16" rear quarter and hatch polycarbonate
- External Power Steering Cooler + inline filter
- Larger aftermarket Power Steering reservoir, custom lines routed along frame rail
- Hardwired GoPro Here 3 Black (auto power on and auto wifi for remote starting)
- Hardwired Rear-facing GoPro Hero 5 Black (auto power on and auto wifi for remote starting)
- Carchet Tire Pressure Monitoring System (TPMS)
- Self-designed and built rear and sideview camera systems.
Mods-Engine
Ported 2g Head by TEM Machine Shop with:
- Forced Performance FP4R2 Cams
- Fidanza Cam Gears, degreed
- Lightened valvetrain, undisclosed
- Plugged EGR port
- Oil port mod
- 99 CAS
2.3L 7-bolt Magnus Motorsports Stroker with:
- 8.8:1 Compression using Magnus custom pistons
- Manley Billet 100mm Crankshaft
- Billet Steel Connecting Rods 150mm w/pin upgrade
- ACL Race Series Main and Rod Bearings
- ARP Main Studs
- Magnus Motorsports head studs
- Oil squirters
- 85.5mm bore
- Align honed
- Felpro headgasket
- Balance shaft removed
- Evo 3 Oil Filter housing w/ported relief valve
- Fluidampr Harmonic Dampener (Crankshaft Pulley)
- Accusump 3Qt unit with electric 25psi valve
- relocated oil filter mount to under driver headlight (to make room for BW turbo o2 housing)
Compworks custom valve cover with x2 -10AN vertical ports
- Calan custom Catch Can
Aluminum Radiator Support (lowered for better duct geometry)
Mods-EMS & Logging
- DSMLink v3
- (Removed 5/14/07) Apexi SAFC2 (just for monitoring)
- (Removed 3/31/18) Apexi EGT/Water Temp gauges
- (Removed 3/31/18) VDO Oil temp and pressure gauges
- Innovate LC-1 wideband with digital gauge (gauge Removed 3/31/18)
- (Removed 5/14/07) Autosports Labs RaceCapture/Pro 2 datalogger with GPS and live telemetry
- Autosports Labs RaceCapture/Pro 3 datalogger with GPS, live telemetry, and Nvidia Shield 8" Tablet for Dash, Samsung Galaxy Tab A 10.1 for gauges, and Raspberry Pi for Heads-Up Display Timing
Mods-Drivetrain
- Quartermaster twin-disc clutch with Clutchmasters street flywheel.
- TMZ Performance "Stage 4" transmission (just about everything he offers) with custom gearing.
- Quaiffe ATB front LSD
- Evo 8 rear LSD with Weir Performance 12-disc upgrade, Frontline Fabrication Diff Cover
- RRT Custom Delrin Differential Bushings
- (Removed 5/12/17) Custom Valved KW Variant 3 coilovers with custom spherical bearing upper mounts, conical/coaxial upper perches, and Swift 900/1000lbs spring
- RRT custom Ohlins TTX36 Shocks, spherical stop mounts, Swift 900/1000lbs springs
- Robispec modified front subframe to provide roll center correction for lowered car
- (Removed 2015) Enkei RPF1 18x10.5 +15mm rims with 315/30/18 Nitto NT01 tires
- Finspeed F110-RT 18x12 +16mm rims with 315/30/18 Hoosier R7 tires
- Finspeed F110-RT Ultra 18x12 +16mm rims with 315/30/18 Hoosier A6 tires
- Modified front and rear knuckles for inboard tire clearance (this is how I can run the above wheel/tire combos) , currently still requres 5mm spacer in rear
- OEM front sway bar, RM Racing rear, poly sway bar bushings
- Front Strut Tower Bar (no name brand)
- Evo X front calipers, Evo 9 Brembo brakes in rear with titanium heat shims, and custom brake ducts up front
- Girodisc 2-piece rotors
- (Removed 5/11/2017) Carbotech XP24 front pads, XP12 rear
- G-LOC R18 front pads, R10 rear
- SPC Upper Control Arm replacements in front with 5.2 caster -3.0 camber, and Ingalls camber adjustment in the rear at -1.9 camber.
- black_gst Solid Aluminum Subframe Bushings
- AMB Aero Widebody package
- Custom rear diffuser (built myself from a Lotus Elise diffuser)
- DHP Composites rear wing
- DHP Composites Carbon Fiber Roof
- Additional vents added to hood for increased cooling and downforce
- Custom Roll Cage by RRT
- Removed AC, Heating, Stereo, and most interior components.
- Sparco Evo 2 seats with aluminum seat bases and Schroth 6-pt harnesses. Driver's side lowered and moved rearward of stock mounting
- Custom Brake Master Cylinder Brace by RRT
- Modified OEM Power Steering Pump to reduce peak pressures (needed due to large sticky racing tires to keep from blowing rack seals)
- Compworks Fender Braces
- Carbon Fiber Doors from Advan Carbon, with custom Lexan Windows by Mr. Spoiler
- (REMOVED 6/2018) Carbon Fiber "Formula GT3" sideview mirrors from APR
- Digital Sideview "Mirrors" using Raspberry Pi system
- 3g Eclipse Master Cylinder
- SRP Racing Pedals
- Paul Volk (99gst_racer) Front and Rear LCAs
- Bobby Gould (ec17pse and FIBA - UK) Rear Upper A-Arms
- Megan Racing Rear Trailing Arm
- RRT installed spherical bearings in rear uprights and front SPC A-Arm anchor
- RRT Custom front LCA cross-brace
- Removed fuel tank steel shielding
- Removed exhaust shielding
Parts Wishlist
- dry sump
- billet knuckles
- lightweight subframes
- carbon/fiberglass hatch
Dyno HP
377 whp
416 lb/ft
Dyno Type
DynoJet
Dyno Session Details
100 octane, RPM-based boost 28psi down to 17psi
Videos
TSiAWD666
Comments
22
Rating
5.00 star(s) 14 ratings
More in 2G DSM
Share this Vehicle
