Please Support RTM Racing
Jmonet1620's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
- Pte 6062 divided t4 .84 a/r
- MF divided T4 small runner manifold
- dual tial 38mvs WG’s atmosphere dumped
- custom 3” vband turbo back exhasut
- custom 2.5” intercooler pipe
- tial BOV
- ETS 3” race intercooler
- 70mm S90 TB
- FIAV bypass plate
- evo3 intake manifold
- FP intake pipe
- magnus heat barrier manifold gasket
- calan V3 catch can
- ohm racing stage3 engine harness
- ohm racing stage3 body harness
- torque solutions engine mounts
- bulfab crossmember
- 90 amp alternator relocated
- small battery kit
- B&M oil cooler
- 1g mishimoto x line radiator
- MF oil return
- msd ignition wires
FUEL
- fic 2150’s
- walbro 535 rewired (10gauge)
- fuel lab FPR
- magnus fuel rail
- -8 ss feed
- -6 ss return
- fuel lab filter
- E85
Mods-Engine
BLOCK
- 2.4LR 4g64 (boostin built stage 3)
- wiesco HD 10:1
- manley turbo tuff rods
- Manley turbo tuff 100mm crank
- ACL main/rod bearings
- arp main/rod bolts
- balance shafts eliminated
- evo 9 OFH
- ported oil relief
- fluidampr
HEAD
- boostin built stage 3
- ported intake/exhaust/combustion chamber
- oversized ferrea valves
- ferrea duel valve springs
- 272/278 kelford cams
- kiggly HLA
- arp custom age 625+ head studs
- arp manifold studs
- MLS head gasket
- MLS manifold gasket
- AEM adjustable cam gears
- FF billet valve cover V1
Mods-EMS & Logging
- DsmLINK w/SD
- Auto meter boost gauge
- auto meter Oil pressure gauge
- auto meter coolant gauge
- innovative LC2 wideband
- GM 4 bar MAP
- GM IAT sensor
- Ingersoll-Rand boost solenoid
Mods-Drivetrain
- QuarterMaster 8leg twin disk
- Boostin built dogbox
• PPG 1-5 gearset
• PPG 4 spider
• quaffe front lsd
• billet bearing plate
• magnus billet shift forks
- DSS stage 2 front axles
- DSS stage 2 rear axles
- DSS stage 2 center driveshaft
- Bostonhatcher rear diff mounts
- fatboy racing billet lockout shifter
- TRE 300m tcase with BP billet mid housing
- D2 coilovers
- RM sway bars
- full poly bushings
- ingals cambers kit
- 5zigen fn01r-c 17x9 +35
- evo brembo brakes
- 255/40-17 Bridgestone RE-71R
- VOLK front control arms
- VOLK front/rear subframe bushings
- power steering delete
Parts Wishlist
For it to run forever
1/8 Mile E/T
7.186
1/8 Mile MPH
106.29
Timeslip Photo Link
Timeslip Details
Track Name : Summit Motorsports park
Nitrous : No
Fuel Used : E85
Vehicle Weight : 3400
Tires : Street Radials
Sponsored Car : no
Dyno HP
707 whp
634 lb/ft
Dyno Type
Mustang Dyno
Dyno Sheet Photo Link
Dyno Shop Name
Buschur racing
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : E85
Turbo : PTE 6062
Boost : 35
TWOpointFORliter
Comments
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
