Jafro's Eclipse GSX
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Build Type
  1. Showcar
Ported and polished ebay 20g with 34mm internal wastegate
- Ceramic Coated Forced Performance Cast Race Manifold
- Ported and polished o2 housing
- Magnus Street 2g intake manifold
- Dejon Intake
- K&N filter
- ADFX FMIC and short-route IC pipes
- Koyo polished Aluminum radiator
- Hayame chrome radiator mounts
- HKS SSQV
- Extreme MBC
- Aeromotive FPR
- Stainless Steel 6AN fuel lines
- FIC -8 AN fuel rail
- Russell 6AN racing fuel filter
- RC 750 injectors
- Apexi N1 3" turbo-back ehaust
- JayRacing Coil-On-Plug setup with Chrysler 300M coils
- Walbro 255 Fuel Pump
- Greddy Trust Electronic Boost and EGT Gauges (removed)
- Jumptronix o2 meter (removed)
- SS braided clutch and turbo oil-feed lines
- Urethane front and rear roll-stop mount inserts
- Dynatek ARC-2 ignition amplifier
Mods-Engine
JE 9:1 compression .020 overbore pistons
Eagle Rods and rod bolts
ARP head bolts
ARP main bolts
ARP valve cover fasteners
No balance shafts
HKS 264/272 cams
Ported, port matched
polished everything inside and out
Mods-EMS & Logging
DSMlink v.2 - AEM 3.5bar MAP sensor - Ramchargers MAFT - LS1 Corvette 3.5" MAF sensor
Mods-Drivetrain
TRE modified transmission with:
*4-spider center differential
*Double 2nd gear synchro
*Heavy-Duty 3/4 gearshaft
*top-speed 5th gear
*TRE shift rails
*EVO Steel 1/2 fork
*EVO Steel 3/4 fork
*BG Synchroshift II synthetic gear oil
*ACT 2600lb pressure plate and street disc
*Raxles front axles
NITTO 450 Extreme Radials 215/55ZR16 on '95 GS wheels (RIP)
Parts Wishlist
Volk TE-37's, Baer Track brake kit.
Background
Bought it from a mom-n-pop used car lot in Harrisonburg, VA in 2001. Third owner. Car from PA. Busted 2nd gear. They asked $14,400 for it, and I paid $7000 cash. Since then, I've replaced at least one of everything on it. The previous owners would be green with envy. Tough luck. It's mine now. It will always be mine.
1/8 Mile E/T
7.730
1/8 Mile MPH
93.830
Timeslip Details
Track Name : Richmond Dragway
Nitrous : No
Fuel Used : Race gas
Vehicle Weight : 3350
Tires : Street Radials
Altitude : 150' ab
Sponsored Car : no
312.0 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
Extreme Motorsports
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Big 16G
Boost : 21
Jafro
Comments
Rating
5.00 star(s) 4 ratings
More in 2G DSM
Share this Vehicle
