- Year
- 1996
- Model/Trim
- Mitsubishi Eclipse GST
- Transmission Type
- Manual
- Mods-Bolt-on
- -----96 Eclipse-----K&N filter, Hallman MBC, 3" Mandrel bent catback, 2.5" Mandrel bent cat eliminator turboback w/ O2 dump, Autometer boost and EGT gauges, Dejon Tool intercooler piping, HKS SSQV BOV, Greddy Large IC, Walbro 190 fuel pump, Home Depot intake, EVO III B16G turbo, MAFT setup, SBR 3500 clutch, Fidanza aluminum flywheel, SBR LSD insert
-----90 Eclipse-----K&N filter, Hallman MBC, 3" mandrel bent turbo back w/ o2 dump, custom IC piping, Spearco bar & plate intercooler, HKS SSQV BOV, Custom intake pipe, MAFT setup, SBR 3500 clutch, Fidanza aluminum flywheel, 660 injectors, Aermotive AFPR, BC springs & titanium retainers, brass valve guides, ferrera valves, 101200 cams, EVO3 16G turbo, EPROM worked ECU, Autometer EGT, Boost, and water temp gauges, Walbro 255lph hp fue
- Mods-Engine
- 90 Eclipse-----101200 cams, BC racing springs & titanium retainers, bronze valve guides, Ferrera valves, ARP head studs, Mitsu 4-layer HG
- Mods-EMS & Logging
- 90 Eclipse----MAFT translator, EPROM worked ECU, data logger, Autometer boost/EGT/water temp gauges.
- Mods-Handling
- 96 Eclipse-----Rota Slipstreams, Tokico Illuminas, Toyo Proxies
90 Eclipse------Rota Slipstreams, Toyo Proxies
- Parts Wishlist
- everything
- 1/4 Mile E/T
- 15.621
- 1/4 Mile MPH
- 90.180
- 1/8 Mile E/T
- 10.154
- 1/8 Mile MPH
- 70.390
- 60' Time
- 2.590
- Timeslip Details
- Track Name : Milan Dragway
Sponsored Car : no
- Dyno TQ
- 0.0 lb/ft
