Please Support Kiggly Racing
Street Build GVR4 555 of 1000
Ownership Status
Currently Own
Mitsubishi Galant VR-4
Turbo Type
GT30 Variant
Drivetrain
AWD
Build Type
  1. Street
GT3076R, FP GT30 turbine housing, Tial MV-r (water coolerd), FP 2.5" o2, FP Race manifold, FIC 2150cc injectors, FIC Fuel rail, JayRacing 340lph pump, Fuelab regulator and filter, -6AN fuel lines, MAGNUS V3 CAST IM, S90 70mm, Spearco 2-120 FMIC (24x8x3.5), 2.5" stainless plumbing, Turbosmart 50mm RacePort BOV, Hal Landry Oil cap - Moroso air/oil separator w/-10AN lines, 4" intake pipe, UR underdrive, Sparco L505 steering wheel w/sparco hub. 3" mandrel bent exhaust. Magnaflow muffler. OEM GVR4 valve cover purchased in 2009.
Mods-Engine
2.3L, Mahle 4032 @ 9:1, OEM 4g64 crank, 2.0L turbo block bored .040" over, GSC 5041 beehives and Ti Retainers, Kelford 272s, UR cam gears (degreed, not set to zero!), Ported/polished head, polished combustion chambers, cleaned/enlarged oil passages.
Mods-EMS & Logging
ECMLink V3. SD. Omni4bar, GMIAT, Innovate LC1WBo2, Blitz SBC-iD and PowerMeter-iD URAS edition - AEM FP and OP senders display FP and OP on Blitz Devices using optional harness and a 12-5v voltage drop.
Mods-Drivetrain
PPG Dogbox. QM Gear drive twin disc.
Kaaz 1.5 way front LSD
5Zigen FN01R-C 17x8 ET35 with RE71R 245/40/17
Rota Grid 17x8 ET35 with Hoosier A7
BC RM inverted coilovers, TCE Wilwood 13" brake kit, TechnaFit brake lines, Whiteline 26mm rear, 22mm front swaybars. Rebuilt LCAs (front) w/energy bushings, AFCO adjustable UCAs (rear), New tie rods, ends, and swaybar links. BoostX rear frame bushings.
Background
Bought the car in late 2010 with bent valves, jdm fmic, evo3b16g on stock boost, cut front bumper. Put a built 2.0L in it with a magnus smim. Wound up swapping some parts for a magnus v3, decided to build a stroker. After going 11.4's a few times and getting sent home from the track, now i just want to autocross and road course the car.
Dyno HP
498.1 whp
425.9 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
Carburetor Connection, Kirkland WA
Dyno Session Details
3 pulls, back to back, 4th gear. 28psi
  • Like
Reactions: faqinshiet
Mitsuturbo
Rating
5.00 star(s) 3 ratings
More in Galant VR-4
Share this Vehicle
