Please Support RTM Racing
GSTwithPSI's 1990 Mitsubishi Eclipse GS-T
Ownership Status
No Longer Own
Mitsubishi Eclipse GST
Turbo Type
16g
Build Type
  1. Street
Ignition:
NGK BPR6ES plugs
NGK Wires
Exhaust:
2G exhaust manifold
Big Evo III 16G turbo (purchased from Forced Performance back in the day)
Turbo back 3" exhaust (no cat)
Stainless O2 housing with atmospheric dump
Intake:
K&N air filter
Open airbox mod
Hallman manual boost controller (in car)
Wet nitrous fogger kit w/ purge, 10lb bottle (jetted for about a 65hp)
Nitrous HUD on steering column
Fuel:
Stock
Exterior:
Stock
Cooling:
Stock
Electrical:
Optima Red Top battery
Mods-Engine
Engine:
Stock 6 bolt short block
New Head gasket (FelPro)
New timing hardware (Gates)
New timing belt and balance shaft belts(Gates belts, changed 11/2012)
Ported Cylinder head
Mods-EMS & Logging
Tuning:
Stock ECU rebuilt by ECMtuning
Greddy turbo timer
Defi D-gauges (boost, narrow band O2)
Mods-Drivetrain
Drivetrain:
Stock manual 5 speed trans
ACT 2600 clutch
Fidanza aluminum flywheel
Stainless clutch line
Brakes/Suspension:
KYB AGX adjustable Struts (4 way front /8 way rear)
Ebach Sportline lowering springs
Front and rear strut bars
Drilled rotors front and rear
17” Motegi Racing FF7 Wheels
Newer tires
Background
I purchased this car in 2005, and sold it in 2013.
GST with PSI
Comments
Rating
5.00 star(s) 1 ratings
More in 1G DSM
More from GST with PSI
Share this Vehicle
