1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Street Build GST Spyder build
Year:
1996
Model/Trim:
Mitsubishi Eclipse Spyder GST
  • Ownership Status:
    I own it
    Drivetrain:
    FWD
    Transmission Type:
    Build Type:
    • Street
    • Drag Race
    Mods-Bolt-on:
    3 inch exhaust,KN cold air intake, mishimoto radiator, front mount intercooler AEM afr,autometer ,oil pressure, water temperature ,boost gauges
    Mods-Engine:
    .20 wisco 9:1 compression ratio,eagle h-beam rods,eagle forged crank, ACL Tri metal race bearings, ACL Tri metal rod bearings,ARP L19,ATI super damper, ferrea stainless steel valves, Kiggly racing beehive valve springs on titanium retainers, HKS cams,850cc injectors,hx35 bullseye hotside, tial external wastegate, Greddy recirculated bov
    Mods-EMS & Logging:
    Dsmlink v3 lite
    Mods-Drivetrain:
    ACT 2600
    Mods-Handling:
    Tein adjustable coilovers. Hankook Ventus RS3
    Parts Wishlist:
    1g black cas, speed density setup
    Background:
    I've had this vehicle for about 9 years it was slightly modified when I received it and then one day the engine went out off timing and destroyed the head. I had never built an engine before but had a passion for doing it so I disassemble the motor send the block out to get bored over and assembled sent the head out to get assembled time the motor myself reassembled it and dropped it back into the car. Who remembers turning over their freshly built motor for the first time it was nerve-racking. Thankfully my persistence and attention to detail the car sputtered and then turned on running smoothly which surprised me.
Share this Item
User Comments
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
