- Year
- 1991
- Model/Trim
- Mitsubishi Galant VR-4
- Transmission Type
- Manual
- Mods-Bolt-on
- - long tube divided equal length race header for a GT42 w/ twin Tial 38mm waist gates
- custom SMIM with tapperd runners and none protruding volocity stacks
-GT4202 with PTE 1.01 divided housing
-Evo3 gear set tranny all parts bought from Jacks, then custom built by me.
-Quarter Master Twin disk clutch.
-10gallon fuel cell, Eliminator fuel pump, FIC Blue Max 2150's, AEM EMS Vs 2, a1000 -10 regulator, etc.
-Stewart Warner gauges, 10k rpm tack, 0-100psi blower gauge, fuel pressure, water temp, oil temp, oil pressure
-PTE water to air IC with sidemount heat exchanger and 4gallons or water and 1.5 gallons of ice for track/race gas
-Tial 50mm bov on W/A end tank.
-4" down pipe
-chrome moly front main structure with removable front end and chrome moly sub frames and solid motor mounts
- Mods-Engine
- Custom CP pistons using KrammLox wire wrist pin retainers, Custom Carrillo rods, 3/4 filled block, custom ported head, felpro perma torque, A1 studs, Crower 415 cams, crower cam gears, and many many more things.
- Mods-EMS & Logging
- AEM EMS vs 2
- Mods-Drivetrain
- custom Jacks tranny built by me, x2 this year :).
Quarter master twin disk clutch
3bolt ring/pinion 4bolt diff
GF Goodrinch Comp T/A new style 225/50/15's x4 street...
Hoosier QTP 9.5x26x15 slicks, I ran these all last year, best tire ever.
- Mods-Handling
- 1g dsm Ksports, 2g slotted front rotors, drilled for the 4 bolt pattern, EBC red pasds and SS brake lines all 4 corners.
- Parts Wishlist
- M and W ignition box and COP, Dog box gear set, Drive Shaft Shop everything.
- 1/4 Mile E/T
- 9.450
- 1/4 Mile MPH
- 156.900
- 1/8 Mile E/T
- 6.300
- 1/8 Mile MPH
- 122.000
- 60' Time
- 1.750
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Track Name : Brainerd Internation Raceway
Nitrous : No
Fuel Used : Race gas
Vehicle Weight : 2550
Tires : Drag Radials
Sponsored Car : no
- Dyno TQ
- 624.0 lb/ft
- Dyno Type
- Dyno Dynamics
- Dyno Video Link
- Watch Video
- Dyno Shop Name
- DB Performance MN
- Dyno Session Details
- Nitrous : No Nitrous
Turbo : Full Garrett
Boost : 44
