1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Please Support Miller Import Parts
Street Build (evo9 mivec swap + EVO9 AWD conversion)
Year:
1997
Model/Trim:
Mitsubishi Eclipse N/T
Share this Item
DSMReviver likes this.
User Comments
  1. ZergBush
    Interior:
    - heater. Mechanically, this block remained from the eclipse. radiator, furnace body and operation mode switches.
    - window regulators. Buttons and motors eclipse.
    - the torpedo of the eclipse is crossed into an alcantara, instead of a passenger pillow - a recess
    - MOMO steering wheel from Evo6 with airbag
    - seats RECARO evo9
    - 4-point belts TAKATA
    - gear selector ego9, handle MOMO
    - floor tune eclipse
    - rear seats, interior panels and Alcantara ceiling with leather
    - carbon frames of instruments and control knobs Evo9
    - motor wiring, torpedo, interior and fuse blocks from evo9
    - headlamps front and rear of course eclipse
    EVO AWD & ENGINE SWAP:
    - ECLIPSE 2g D31A 420a
    - EVO9 4G63 mivec turbo engine
    - EVO9 5spd manual AWD transmission
    - EVO6 transfer case
    - EVO7 propeller shaft
    - EVO10 front Brembo brakes
    - EVO9 rear Brembo brakes
    - EVO6 steering wheel
    - EVO9 RECARO seats
    - EVO9 wiring
    - LEGNUM front arms
    - LEGNUM rear arms
    - LEGNUM fuel tank
    - LEGNUM awd rear diff
    - custom intake
    - custom exhaust
    - custom cooling system
    - custom oil system
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
