- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Mods-Bolt-on
- FP HTA T4Z (Ceramic Coated w/DEI Turbo Blanket) -
TAB Fab T3 Exh Mani (Ceramic Coated) -
JM Fab Drag SMIM l
Boomba Racing 75mm TB w/Adel Wiggins -
DV/DT Fab FMIC -
3" Intercooler Pipes -
3.5" Open Downpipe (Ceramic Coated/DEI Heat Wrapped) -
TiAL 44mm WG -
TiAL BOV -
SparkTech Sequential COP -
FIC 2150cc Injectors -
RCI Anodized Fuel Rail -
RCI 10gal Fuel Cell w/Sender -
2x Jay Racing Pro 044 Pumps -
2x -8an RCI 100mic PrePump Filters -
Aftermarket Industries Fuel Pump Bracket -
-6an Fuelab AFPR -
-8an Fuelab Fuel Filter -
-8an Pro Nylon Fuel Feed -
-6an Pro Nylon Return -
Saturn 200amp Alt -
AFCO 80107N w/-16 AN -
Marc Evans Catch Can -
Optima Red Battery -
HID 10000K -
GM Fiberglass Dash -
Carbon Fiber Hood/Hatch/Doors/Mirrors
- Mods-Engine
- 1g Head:
JMS Port/Polished (Ceramic Coated Chambers/Exh Ports) l
FP3 Cams l
Kiggly Beehive Valve Springs/Retainers l
Engnbldr 1mm Over Valves (Cryotreated/Ceramic Coated Faces) l
Kiggly HLA Regulator l
3g Lifters l
HKS Cam Gears l
HKS Timing Belt l
6 Bolt Block:
2.3 Stroker l
Wiseco 1400HD .20 Over Pistons (Ceramic Coated Tops) l
Manley "I" Beam Turbo Tuff Rods (Cryotreated/Ceramic Coated) l
OEM 2.4 Polished Crank (Cryotreated/Ceramic Coated Counterweights) l
Kiggly Main Girdle l
ARP L19 Headstuds l
ARP Mainstuds l
ACL Race Rod Bearings (Cryotreated) l
Clevite Main Bearings (Cryotreated) l
Felpro MLS Permatorque l
Fluidampr Harmonic Damper w/ARP Bolts l
BSEK l
Zaklee Timing Cover l
STM Oil Dipstick l
- Mods-EMS & Logging
- ProEFI 128 ECU l
ProEFI 5 Bar Map l
ProEFI 150psi Fuel Pressure l
ProEFI 150psi Oil Pressure l
ProEFI Wideband l
ProEFI IBoost Switch l
GM IAT l
Racepak IQ3 Digital Dash l
- Mods-Drivetrain
- AWD Conversion l
QuarterMaster Twin Disc 7.25" V-Drive Clutch w/Flywheel l
3" JMS Driveshaft l
SS Full Clutchline l
Rear LSD l
Three-Speed Scatter Shield l
Aluminum Shifter Base, Cable, Cable Bracket Bushings l
Aluminum Rear Differential Bushings l
Aluminum Driveshaft Bushings l
- Mods-Handling
- Bill Bucks 10-Point Cage l
Stroud ProStock Chute l
Kirkey Pro Drag 18" Seats l
Stroud 5-Point Harness l
Sparco L550 Steering Wheel l
NRG 2.5 Quick Release l
15x7' Volk TE37 l
Mickey Thompson 235/60/15 Drag Radials l
DGR Lightweight Lugs l
ARP Extended Studs l
Front & Rear TCE Wilwood Drag Brakes l
-3an SS Full Brake Lines l
Frontline Fab Brake/Clutch Reservoir l
Avid Racing Billet Left & Right Motor Mounts l
Chromoly Front Motor Mount Arm l
Solid Aluminum Rear Motor Mount l
Prothane Total Suspension Kit l
Aluminum Front/Rear Subframe Bushings l
RM Sway Bars l
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
