Road Race Build Dads Road Car
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
T25
Drivetrain
AWD
Build Type
  1. Road Course
K&N 7" filter, Injen intake pipe, Greddy upper pipe, Greddy Type-S BOV, Fluidyne radiator, Samco black hoses, BR7ES Plugs, NGK wires,
Mods-Engine
99 split thrust washer motor: Manley H-Beams, Manley 9.5:1 pistons, all ARP hardware, balance shaft delete, evo III oil filter housing,
Cylinder head: ARP head studs, Kiggly HLA, Manley springs, GSC S1's, Fidanza adjustable cam gears
Mods-EMS & Logging
EvoScan/ Ecuflash w/CeddyMods and tactrix 2.0 cable, Autometer digital oil pressure gauge with sensor remote mounted,
Mods-Drivetrain
Shifter base bushings, under hood shifter bushings, Solid rear motor mount, tubular crossmember w/ front solid motor mount, solid clutch line from master to slave, ARP wheel studs
front and rear DC Sport strut bars, RMSDsm Racing rear sway bar, 17x9 +35 Enkei PF01ss, Bridgestone Potenza RE-71R 255/40/17, 3g brake master cylinder, steal braided lines from master to proportioning valve w/ proper fittings, Evo 9 Brembos front and rear calipers, Evo Stoptech Slotted front and rear rotors, Evo Hawk HP+ pads, DSM FTP brake lines, Motul RBF600 brake fluid, upgraded power steering cooler and reservior
*waiting to go on*
Volk Metalcraft front lower control arms, ec17pse front upper control arms, rear lower control arms, rear lateral arms, rear trailing arms, 3g brake booster (if needed),
Parts Wishlist
coilovers and track alignment
Background
A car my dad and I are building for him to take to the road course.
EclipseRacing99
More in 2G DSM
Share this Vehicle
