Please Support Rix Racing
CODE4's Eclipse N/T (w/turbo)
Mitsubishi Eclipse N/T
Mods-Engine
Race port & polish cylinder head
PT hydraulic lifters
Mopar 2.7L cam followers
Crower Stage 3 Camshafts
Crower 4G63 spec valve springs and titanium retainers
Mopar OEM valve keepers
SI 1mm oversize stainless steel valves
SI Bronze Valve Guides
Mopar OEM valve seals
Boomba Racing adjustable cam gears
ARP Cam studs
1999 Stratus Block - 2.4L EDZ
0.020 overbore
JE Pistons 8.5:1
JE Piston Rings
Crower Connecting Rods
Mopar OEM main and rod bearings
ARP Main Studs
ARP Head Studs
Ishihara-Johnson Crankscraper/Baffle/Windage Tray
Balance Shafts Removed
SRT4 Oil Pan & Pickup
SRT4 Timing belt Tensioner
SRT4 Water Pump
SFI rated Flexplate
SouthBend 6 Puck Ceramic Sprung, AL Flywheel
ARP flywheel hardware
Treadstone Turbo Manifold
GT3076R 2.5" V-Band
TiAL 38mm Wastegat
Mods-EMS & Logging
MegaSquirt II v3.0, p&h board, sequential injection, RC 750cc,
Many Autometer Ultralite gauges
Mods-Drivetrain
SouthBend 6 Puck Ceramic Sprung, AL Flywheel, 3.55 Stg 3 Trans, Quaife LSD, DSS Level 5 Axles & hubs
DGR Suspension Coilovers with 15k/8k SWIFT springs
RMDSM Sway Bars
Tanabe Front and Rear lower tie bars
DC Sports rear strut bar
Evo VIII Enkeis 17x8 +35 powdercoat black
Yokohama S.Drives 245/45/WR17
Parts Wishlist
Cage, seats, harnesses.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
393.2 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
Proven Power, Tampa, FL
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : Full Garrett
Boost : 28
CODE4
Rating
5.00 star(s) 1 ratings
More in 2G DSM
Share this Vehicle
