Please Support RTM Racing
Clean Look
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Build Type
  1. Street
Mods-Engine
Cylinder head porting EGC Energy Division Stage 1 camshafts 268/268 Hundai OEM rocker customizer Fidanza adjustable cam followers - "limited edition" black gate racing performance racing kit Timing Gates substantially once-a full set of original turbo inlet manifold porting + Magnus heat seal the intake manifold top pistons with rings, Kit 8.0: 1, Mitsubishi Lancer Evolution service 8 turbo cranks OEM MMC metal head gasket ARP head studs true evolution of Mitsubishi MHI turbocharger 3 stainless steel oil supply line is removed USR deleted cruise control valve cover paint the clear cover cam gear at psi spark plug cap oil Greddi OEM external oil cooler filter assembly with the bracket: Mitsubishi Lancer Evolution 3 OEM custom oil cooler kit oil catch tank Prothane Motor Mount Inserts Greddi radiator cap 1.3 kg / cm2 of sports samco radiator hose kit
Mods-EMS & Logging
OEM Mitsubishi Lancer Evolution 8 ECU AEM Tru-boost gauge-regulator-type sensor type AEM wideband UEGO controller Omni-Power Mitsubishi Universal DBP 3 bars turbo timer
Mods-Drivetrain
Manual transmission swap, swap OEM limited slip rear differential clutch Goodridge full range of Megan Racing short shifter kit power consumption shifter Suspension Kit DSM under the hood bearing Changeling Street Lite flywheel act act act 2600+ Street disk
Tein Super Street coilovers kit + stand-alone self-regulatory turmoil set of custom front strut tower brace custom rear strut tower brace energy consumption suspension hyper-Flex master bushing kit OEM Mitsubishi Galant VR - 4 Front knuckle (160 mm) Custom Front collapse Ingalls tuner Tuner collapse of the rear wheels (-1 ° to + 3 °) OEM Mitsubishi Lancer Evolution 8 (Brembo) Goodridge brake line kit Kosei OP Magnum wheels 18 Federal SS 595 RS - R tires (225/40/18) TPI nuts made black Custom front and rear wheel spacers
1/8 Mile E/T
7.460
1/8 Mile MPH
92.020
Timeslip Details
Спонсором автомобиль : нет
415.5 lb/ft
zer_0
Comments
6
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
