chaye's Eclipse GSX
Mitsubishi Eclipse GSX
SBR ballbearing GT10, turbo xs standard boostcontroller, FIC 780cc injectors,walbro 255lph fuel pump, Fullthrottlespeed FPR, Dsmlink ECU, Magnecor plug wires, NGK sparkplugs,ACT XACT flywheel, ACT 2600 lbs clutch kit,externallydumpedO2, apex'i 3" cat eliminator downpipe and apex'i N1 3"catback, ported 2gmanifold, HKS SSQ BOV, Dejoontool racecore FMIC, GM maft(blowthrough set up)
Mods-Engine
6bolt 4G63 swap, WISECO pistons(.30"overbore, 8.5:1 comp), Balanced and blueprinted bottom end, clevelitte77 bearings, balance shafts removed, MLS headgasket, ARP headstuds, MR. GASKET overhaul gasket kit, rebuilt head from slowboy racing
tokico 5-way adjustable struts, EIBACH coilovers, ignalls camber kit, front and rear strut tower bar. 17" ADR Sukudo spoke 10, falken Z 45/215 tires, brembo crossed drilled rotors, stainless steel brake lines.
Parts Wishlist
AEM wideband O2 sensor, coil on plug ingnition set up, Turbonetics esxhaust manifold, 40mmtial external wastegate,HKS 264 272 cams with gears and springs with new revised lifters, GM map sensor, Suspesion technic swaybars, 97-99 eclipse conversion,
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Vehicle Weight : 3400
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
chaye
More in 2G DSM
Share this Vehicle
