Calan's Talon TSi AWD
Eagle Talon TSi AWD
Build Type
  1. Street
Ported/coated HX40/FP Race manifold/recirc O2 housing : Tial knockoff 38mm gate
Short Route FMIC/Custom piping
Electronic boost control
Dual Walbro 255's w/-6AN supply line
Golan large fuel filter
Aeromotive AFPR
FIC BlueMax 1350cc Injectors
RRE DP, 3" custom exhaust with DMH e-cutout
DevilsOwn WAI Progressive Kit
Stock ignition
Alum. Radiator/Slimline Fans (10")
A/C removed
Modified Prothane motor mounts
Custom intake, PS lines, coolant tank, catch cans, etc.
Mods-Engine
2.3l stroker ; Wiesco 8.8:1's/Eagle crank & rods
B/S removed
EPN SS valves
Kiggly springs/retainers and HLA regulator
3G revised lifters
Forced Performance FP2/FP2 (272/272) cams
Fidanza ACG's
Fluidampr HB
Felpro Permatorque MLS HG and L19 studs
Brad Penn 20w-50 oil
Mods-EMS & Logging
Zeitronix WBO2 with dual-function gauge, EGT and MAP sensors : ECMLink v3 : SD & E85
Mods-Drivetrain
Rebuilt Tranny - 4-spider diff/double synchros/etc.
Southbend pressure plate/ClutchNet clutch
Fidanza aluminum flywheel
All metal shifter and linkage bushings
Modified Fidanza short-throw shifter
New OEM driveshaft/CB's
New OEM axles
Redline MT-90 and Redline Heavy Shockproof gear oils
Eibach Prokit/KYB AGX Struts
BF Goodrich G-Force Sports 235/40/17 ZR
Eagle Alloy (Boss) 318's
Ingall Adjustable Rear upper control arms
Front camber bolts
93+ rebuilt front calipers
Rebuilt rear calipers
Brake Performance slotted rotors
RM rear sway bar w/custom end links
Active toe eliminator kit
Prothane bushings throughout
Parts Wishlist
4R Cams
Body and paint
New stage 23432511 built transmission
1/8 Mile E/T
10.21
1/8 Mile MPH
63.170
224.0 lb/ft
Calan
Comments
More in 1G DSM
Share this Vehicle
