- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Automatic
- Mods-Bolt-on
- FP30H1E__FP Race Manifold__Tial Wastegate__4" Intake w/ K&N__Magnus SMIM__Bosch 1600cc__Sniper Wet Kit__SBR Race FMIC__In-Tank Walbro 255hp__In-Line Walbro 255hp__Aeromotive FPR__Golan Fuel Filter__-8 Feed Line__Magnacore Wires__3" DP w/ cut-out__NGK BPR7's__SPAL Puller__Urethane engine mounts
*Weight Reduction*
Complete A/C & Heating, Power Steering System converted to Manual, Front bumper reinforcement, Front & Rear windshield wiper assemblies, rear seats & bracing, Hood latch & bracing, sound deadening, wheel wells, car audio & antenna, CC delete, all plastic interior (minus dash, door panels & center console) = 2,750lbs. (no driver & 1/2 tank of gas)
- Mods-Engine
- Bottom: Stock Crank, BSEK, CP 9:1 Pistons, Eagle Rods, ARP head studs, SS O-Rings, Hussey Copper HG
Top:
Re-Built Head, 3 angle valve job, BC 280's degreed straight up, BC Springs & Ti Retainers, Fidanza Adj. Cam Gears, 3G lifters
- Mods-EMS & Logging
- DSMLink V3__GM-MAF__Zetronix Wideband__MSD DIS-2__Auto Meter: Fuel Pressure, Boost. Oil PSI, Trans Temp__iEquus Water Temp__Blitz Turbo Timer w/ boost peak/hold/warning__Summit Shift Light
- Mods-Drivetrain
- IPT: End Clutch & Re-stalled Converter__Trans-Lab Shift Kit__B&M: Trans Cooler & Quicksilver Shifter__4-Bolt Rear LSD__Kiggly Mod
- Mods-Handling
- KYB AGX Struts__Ground Control Coilovers__Eibach Front Camber Kit__RX-7 Wheels on Yokohama AVS ES100__Drag DR17 on Hoosier QTP's__Energy Suspension full chassis kit__RRE extended wheel studs
- Parts Wishlist
- 8 or 10 point cage, Lexan Windows, Paint Job
- 1/4 Mile E/T
- 10.788
- 1/4 Mile MPH
- 131.110
- 1/8 Mile E/T
- 7.015
- 1/8 Mile MPH
- 103.000
- 60' Time
- 1.677
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Track Name : Autoclub Dragway
Nitrous : Yes
Fuel Used : E85
Vehicle Weight : 2950
Tires : DOT Slicks
Altitude : 1,158
Sponsored Car : no
- Dyno TQ
- 414.8 lb/ft
- Dyno Type
- Dynapack
- Dyno Shop Name
- Road Race Engineering, CA
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Race gas
Turbo : FP3575
Boost : 29
