- Ownership Status
- No Longer Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Road Course
- Mods-Bolt-on
- - Forced Performance cast Race Manifold- ceramic coated
- Punishment Racing O2 housing W/- Tial MVS 38mm wastegate- ceramic coated
- Punishment Racing 3" SS Downpipe
- Megan Racing SS 3" test pipe
- 3" SS Tsudo, SS Cat-back exhaust
- Ported/ceramic coated turbine housing 7cm TDo5H 20g
- Tial BOV
- Aluminum Mishimoto 3 core x-line radiator
- flex-a-lite (model #420) dual fans
- VRSF core with modified short route piping
- Dejon 1G intake W/ K&N from a trx250r
- 66mm Throttle body (N/A 3000gt)
- EGR blockoff plate
- FIAV bypass plate
- Energy suspension Engine mounts
- AEM FPR
- Walbro 450 w/ holley hydramat pump filter
- FIC 1100 High z injectors
- Fluidamper Harmonic damper
- Mods-Engine
- - ARP headstuds
- Mitsubishi 4lyr head gasket
- Balance Shaft eliminator kit
- GSC zero tick lifters w/upgraded "stiff" springs
- EPN SS Valves
- 3 angle valve job
- Brian Crower springs/Titanium retainers
- EPN Bronze valve guides
- Ported head
- Gates kevlar Timing belt
- BC 272 cams
- AEM cam gears W/ ARP bolts
- Mitsubishi forward facing OFH
- Mishimoto thermostatic oil sandwich plate
-10 row oil cooler
- Mods-EMS & Logging
- - PLX muti-gauge Wideband
- ECMLink V3 full
- Auto meter mechanical boost gauge (-30 to 45psi)
- Auto meter electric oil pressure gauge
- Speed density (AEM 3.5 Bar map / AEM IAT)
- GM Ethanol sensor (True flex fuel)
- IR BCS
- Mods-Drivetrain
- - Competition clutch w/ Segmented Ceramic disk
-ACT 11.5Lb Flywheel
- Built trans (Jacks transmissions),
- LSD's front and rear ( Symmetrical AWD)
- Mods-Handling
- - Megan race series coilovers
- XXI 17" rims w/BFG sport comp II
- Polyurethane bushings all around
- ST 25mm Rear Anti-roll bar
- Ingalls rear adjustable upper control arms
- (uninstalled) EVO 8 brembo calipers (will be installed soon)
- 1/4 Mile E/T
- 12.493
- 1/4 Mile MPH
- 113.30
- 1/8 Mile E/T
- 8.122
- 1/8 Mile MPH
- 89.10
- 60' Time
- 1.824
- Timeslip Details
- This was my first time at a drag strip, straight line racing is not really my cup of tea... The car is equipped with full interior and accessory's, I have zero weight reduction mods.
