Street Build Black betty
Ownership Status
Currently Own
Plymouth Laser RS Turbo AWD
Drivetrain
AWD
Build Type
  1. Street
  2. Autocross
  3. Road Course
Tuning
Oil pressure gauge
Dsm link v3
Scg1 wideband.
Engine
1g rods with NPR 2g pistons and rings
Top line gasket And Seal set OEM head gasket.
King race bearings for rods and mains
Block was honed to pistons using a torque plate After Main Girdle And Arp Head Studs Were Installed And Torqued To spec
Hot tanked
Bored .020 To Clean Walls
FFOFH.
Brass fittings for FFOFH
HEAD
Hks 264 cams
new coil pack 1
NGK plugs
Arp head studs
Revised 3g lifters.
S90 throttle body
Aem adjustable timing gears
Ported and rebuilt cyclone intake manifold using a 20psi holset wastegate actuator
Turbo
T3 .70AR BEP hx35 with erl manifold
Grimm speed MBC
braided turbo feed from OFH
10 AN turbo return
12an welded return for future build
new SS gaskets for turbo.
Tial 44mm wastegate.
FUEL
fuel labs AFPR with new orings
Walbro 255 in tank
Walbro 450 in custom build 1gallon surge tank
FIC 2150s high z
SUSPENSION
225-45-17 BFG C2 A/S
Stack house fabrication fully adjustable control arms
Stock house fab tubular K member
Brakes
Ctsv big break kit in the front
Stop tech evo 8 braided lines
Body
New speedometer cable
Transmission
solid bushing kit with new linkage
Rebuilt transmission from jacks with double synchros and upgraded gear set
Extra
new autozone battery
Battery relocate to trunk
Emissions delete with egr plate
Cruise control delete
Tial Q bov
new Autozone starter
OPL all alum radiator
Custom built coolant swirl pot with gmc thermostat
16an radiator lines
Mods-Engine
HKS 264s
Arp head studs
Stock 6 bolt block with 7 bolt pistons
King main bearings and rod bearings
Mods-EMS & Logging
ECMlink V3 socketed 92 ecu
ECMlink no lift to shift
Innovate scg1 widenand
Mods-Drivetrain
Solid shifter bushings
Jacks trans with dual synchros and revised gear set
Parts Wishlist
Ppg dog box
  • Love
Reactions: TheRippedNerd
Jacob hoke
More in 1G DSM
Share this Vehicle
