- Ownership Status
- No Longer Own
- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Big16G turbo, XS Power Tubular Manifold -
FFWD Copper Gasket set, EGR Blockoff Plate, and OEM Manifold Studs- rebuilt throttle body with 63mm bore with new ISC and FIAV Bypass
2g MAF, K&N Filter, and 2g Hard intake pipe 550cc RC's, PR O2 Housing Powered valve cover and pipes, walbro 255 rewired
2.5" Downpipe w/ wideband bung 2.5inch straight pipe to a 3inch megan racing muffler non-cruise throttle cable, Mishimoto slim fan, FueLab AFPR and install kit, and poly motor mount inserts IDEI header wrap and a flange to finish up my exhaust
Mishimoto radiator, VSRF Front Mount kit and used J-pipe- RS Type BOV-
- Mods-EMS & Logging
- hallman manual BC Apexi SAFC Autometer Cobalt Boost Gauge and Pod - Innovate MTX-L Wideband ,
- Mods-Drivetrain
- ACT 2100 clutch
Rebuilt transmission by a shop in Monroe Michigan. Poly trans mounts aluminum clutch and shifter, and shifter mount bushings. Short throw shifter,
- Mods-Handling
- OEM suspension, 1g talon wheels, street tires
- Parts Wishlist
- Wanted to get a semi built head, dsmlink for it, and 1200cc injectors.
