- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- GT30 Variant
- Transmission Type
- Manual
- Build Type
- Road Course
- Mods-Bolt-on
- PTE GT3076R .63A/R AFCO Scirocco radiator mounted forward - custom sealed hood-vented radiator ducting - FP Race manifold - FP3 cams - side exit exhaust - FIC 1450cc - Walbro 255HP + -255HP in-line - Tial BOV - A'PEXi GTR FMIC w/ JMFab piping - custom length Magnecore race plug wires
- Mods-Engine
- 2.3L stroker 6 bolt, Mahle 9.5:1/Eagle rods, PermaTorque MLS, ARP hardware. ClutchGSX ported/polished 1g head, polished/matched combustion chambers, 3-angle valve job, 1mm over Ferrea valves, custom beehive springs, FP2 cams, '90 oil filter housing w/-10AN external oil cooler
- Mods-EMS & Logging
- AEM Infinity EMS - AEM AQ-1 Datalogger system - sensors: GPS, oil pressure, fuel pressure, brake pressure, MAP, IAT, Lambda
- Mods-Drivetrain
- stock trans w/ Neo RHD fluid - QuarterMaster V-Drive Twin Disc clutch 7.25
- Mods-Handling
- Full custom DOM 1.75x.095 roll cage w/integrated chassis wing mounts for APR GTC-300 rear wing - DG-Spec revalved Konis, spherical uppers, Hypercoil 900#F/450#R - custom brake system with Wilwood adjustable brake prop valve - Rotora BBK (4 piston w/ 13" rotors) - Evo rear Brembo brakes w/RacingBrake 2-piece rotors - CL-Brakes RC8 race pads - Volk CE28N gunmetal 17x9 +35mm with 255/40-17 595RSR
- Parts Wishlist
- EFR7670 turbo, finish front end ducting and tubular radiator support to mount splitter to frame
- Background
- compete in West Coast time attack events
