Please Support JNZ Tuning
Street Build AWD spyder
Ownership Status
Currently Own
Mitsubishi Eclipse Spyder GST
Turbo Type
GT35 Variant
Drivetrain
AWD
Build Type
  1. Street
GTX3584RS t3 .82ar, JMFab exhaust manifold, JMFab intake manifold, ShearerFAB FMIC 4.5" garrett core, Synapse BOV, Tial MVR wastegate, S90 70mm throttle body, torque solutions motor mounts, AEM cam gears, EVO rear brakes, wilwood front brakes, 3" exhaust, Seibon CF hood, walbro 400lph pump, -8AN fuel feed line and -6AN return, 1550cc high impedance injectors, tubular rear subframe with volk arms
Mods-Engine
Hybrid 6-bolt eagle rods 22mm wrist pin, wiseco 9:1, Curt brown head, GSC valves, Kelford 272, evo rockers, kiggly springs, ATI balancer
Mods-EMS & Logging
dsmlink v3 SD
Mods-Drivetrain
DSS stage 3 front axles, DSS stage 5 rear axles, DSS 3" aluminum driveshaft, 300m upgrade transfer case, FrontlineFab rear diff cover. quatermaster 8 leg, PPG gearset with cusco front diff, boostin 300m output shaft, evo 3 rear diff with upgraded weir 12 plate TRE ninja side plate built buy shep.
k-sport coilovers, energy suspension rear bushing kit, torque solution rear subframe bushings, solid rear diff mounts, solid carrier bearing bushings.
Dyno HP
697.5 whp
517.2 lb/ft
Dyno Sheet Photo Link
Dyno Session Details
525whp 390ft/lbs on pump gas 695whp on C16
babyviper
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
