Autocross Build 98 Talon AWD Street Modified
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Autocross
FP Intake & K&N Filter
Injector Dynamics 1000cc Injectors
Walbro 255 fuel pump
Evo III Intake Manifold & Fuel Rail
63mm Uber Seal/Max Shaft Throttlebodys.com
Custom 2.5" custom Intercooler piping
ETS 7"x3.5" Street Kit Intercooler Black Anodized
IR Aro Boost control solinoid
Tial Q 50mm BOV
FP 68HTA Turbo, Ported Exhaust, External Wastegate, 7cm housing
FP Race Manifold (Jet-Hot coated)
TPP Manifold Blanket
Evo III O2 Housing
Custom down pipe & Coastfab 4.5" x 17" Racing Muffler
Custom Catchcan
AEM 3.5 bar map sensor
AEM IAT Sensor
3qt Accusump with EPC Valve
RRE front and rear strut bars
Antigravity AG-1201 Battery (2.5 lbs)
Koyo N-Flo Radiator
12" Slimline High flow fans
Ohm Racing Hoses
Fuelab Fuel Pressure Regulator
Fuelab Fuel Filter
Cruise Control Delete
A/C Delete
Emissions Delete
Sunroof Delete (Carbon Fiber panel custom mount)
Duraflex Vented Fiberglass Hood (modified for weight reduction) with Aerocatch Latches
2GB Eclipse Headlights
Paint Code matched Tinted Tail Lights and Front Corner Markers
Mods-Engine
1999 Split thrust bearing block
Map Ultimate duty H11 head studs
Avid 75A motor mounts
Mods-EMS & Logging
DSMLink V3
AEM Boost Gauge 30-4406
AEM Air/Fuel Gauge 30-4100
AEM Oil Pressure Gauge 30-4401
AEM Fuel Pressure Gauge 30-4401
AEM Water Temp Gauge 30-4402
Mods-Drivetrain
Jacks Stage 5 Transmission DOA
Stock trans
Evo 3 input shaft and 1st gear (not installed)
Torque Solutions shift cable bushings
Quartermaster Twin Disc Clutch & 7lb flywheel
Competition Clutch Fork
Quaife Front Diff
4 Spider Center Diff
Evo 3 tarmac 35/65 center diff (not installed)
Boostin 3M Transfer Case
DSS Carbon Fiber Driveshaft
Aluminum Carrier Bushings
Boston Hatcher Rear Diff Mounting kit
TRE Evo 4-6 JDM Rear Diff with Max-Lock, HD Side Cover & Frontline Fab Back Cover
Evo 3 rear cups
Front and Rear Aluminum Subframe Bushings
Evo 8/9 front and rear brake calipers
Giro disc 2 piece front and rear brake rotors
ARP Wheel Studs
Penske Triple Adjustable Remote Reservoir Coilovers (Borrowed, thanks Charles, Fedja)
Cut & Welded Front Upper Control Arms
Volk Metal Craft Front Lower Control Arms
ec17pse Rear Upper Control Arms with Ingalls camber kit
ec17pse Rear Lower Trailing Arms
ec17pse Rear Lower Control Arms
Enkei RPF1 18x10.5 15et (thanks Charles)
265/35/18 Yokohama A052 until I feel like Hoosiers again
Konig Hypergram 18x11 15et
285/30/18 Bridgestone RE-71RS
Homemade front splitter, Professional Awesome mounts and supports
68" Wide Dual Element 9lives Wing, custom wing mounts
Background
Autocross car since 1998, over 300 events.
1998-2009 G Stock, D Stock
2010-2011 E Street Prepared
2016- Street Modified / eXtreme Street A
Dyno HP
313 whp
305 lb/ft
Dyno Type
Mustang Dyno
ileagleracing
Comments
12
Rating
5.00 star(s) 4 ratings
More in 2G DSM
Share this Vehicle
