Please Support RTM Racing
Please Support Rix Racing
Street Build 95 Eagle Talon awd build
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
20g
Drivetrain
AWD
Build Type
  1. Street
VRSF FMIC
Tial MVS 38mm wastegate
Tial Q bov
HKS cat back
EBay 3” DP
Punishment Racing o2 housing open dump
Avid mounts
Aluminum radiator
Mishimoto 1.3 bar radiator cap
Gamble garage coolant res tank
G-plus coolant hose kit
SS clutch line
SS oil feed
SS lines for boost controller
Hallman Black BC
FP blanket
FP intake with two -8an bungs/ K&N filter
FP race manifold
FP Green Turbo
OEM turbo drain
Fuel lab afpr
Fuel lab fuel filter
Sealed 3 port catch can
JMF small battery kit
Mods-Engine
BC 272 cams
3g lifters
Eagle rods
Wiseco pistons
ARP rod bolts
ARP head studs
ARP main studs
ARP cam bolts
ARP flywheel bolts
BS delete
FIav delete
ISC delete
EGR delete
A/c delete
Felpro composite HG
Fidanza adjustable cam gears
Oem timing components
Gates racing blue Kevlar belt
Thermal intake manifold gasket
Thermal throttle body gaskets
1g TB
EVO 2 intake manifold
Clear upper timing cover
-8an vented valve cover
Mods-EMS & Logging
FIC 1100cc high impedenace injectors
97-99 cas
Oem coils
255 walboro
AEM wideband
ECMLINK V3 Full on SD
Ecmlink PNP harness
Mods-Drivetrain
Fidanza flywheel
Act 2600 with street disc
Redline fluids
B&m short shifter
Polyurethane shifter base bushings
White shed shifter cable billet bushing
D2 coilovers
Front upper strut bar
Rear upper strut bar
Stoptech front BBK
SS brake lines
JNC te37 in white 17x8.25 et 32.
225/45/17 all seasons
Parts Wishlist
Carbon Fiber hood✔️, fenders, hatch
Fp Black
450 walboro
D2 coilovers✔️
Background
Picked up the awd shell for $400. After starting my build based around the panda (fwd), I then switched my focus onto the awd model. This car had been sitting for a couple years with no love.
She was completely stock when I got the shell. No engine. But all the drivetrain was still there. I had A LOT of nuts bolts and random pieces missing.
Ninja edit:
8k miles on the new build and she’s running great.
Armando Elepan
More in 2G DSM
Share this Vehicle
