Street Build 500+HP DD build
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
big 16G with a billet wheel, FP manifold,VRS FMIC
Mods-Engine
This build is going to be a stock 6 bolt block build
-Head MLS Head Gasket,ARP Head Studs,Kelford 272 cams,Kiggly valve springs,Kiggly HLA.
-Drivetrain Stock Trans,Stock T-case,Stock axles,Stock Rear end and Stock driveshaft.
-Clutch is a ACT heavy PP with a 6 puck sprung disc.
-Suspension KYB AGX with Lowering Springs.
-Fuel 1600cc injectors Aeromotive AFPR -8 Fuel lines Walbro E85 450LPH pump.
-Turbo Holset hx35,FP manifold,Tail 44mm Gate.
-ETS Rces Intercooler with VRS Intercooler piling.
-Stock Eprom ECU with ECMLINK full.
-Speed density,4bar map.
-Custom 3 Inch Exhaust .
-Stock intake manifold.
Mods-EMS & Logging
ECMLINK/SPEED DENSITY
Mods-Drivetrain
STOCK MITSUBISHI 4 BOLT
N/A
Background
This is a 73k original miles 91 dsm, this car is going to be a high HP DD car!everything works on this car ac and so on. The last build i did was very close to this build and made 531 @30 psi on E85. this car will be on e85 as well and i will be changing some things on this build over the last build. i have a extra 4g block that i am building but the main goal for this car/build is to be the highest HP stock 6 bolt around my location and more!
1glife
More in 1G DSM
Share this Vehicle
