4seaer's Eclipse GST
Mitsubishi Eclipse GST
Drivetrain
FWD
Build Type
  1. Street
  2. Road Course
  3. Showcar
PTE 6466 ball bearing turbo, FIC's 1150 injectors, magnus fuel rail, Fuel Lab fuel pressure reg., all the braided lines and AN fittings, rewire kit, B&M fuel pres. guage, fuel lab inline fuel and oil filters, B&M oil cooler, S90 throttle body billet 70mm, FP custom exhaust mani., 3 in. V-band exhg.,no cat, K&N air filter, 2 1/2 in. intercooler piping from the TB to turbo...Garret 3" core, Altima batt. yellow top, Frontline fab. catch can, frontline Fab aluminum valve over and CAS cover, Flexalite slim fans, 44mm Tial waste gate, polyu. motor mounts, clear timing belt cover, OBX adj. cam gears, mits.x-line rad., Mitsumoto racing hoses and gates timing belt, Tial 50mm blow off, NGK 9's, Dynotec full ignition, 140 Amp alternator, JM Fab Race SMIM, Fluidampr harmonic damper...
Mods-Engine
.40 bottom fully built, balance shaft eliminated, kelford 280 cams, Kiggly racing BeeHive springs and retainers, Ferrea 1mm valves and Ferrea everything else, 3g lifters, ARP L19 Head studs, Com. Head gasket...
Mods-EMS & Logging
ECM tuning Ver.3, Speed density, GM 3 bar, knock box, Apexi turbo timer, all the norm autometer guages... Apexi wide band...
Mods-Drivetrain
Fully built B&M double synchros trans Cryo. Gen. gears limited slip, 2600 ACT, ACT fly wheel, ext. rod on slave cyl., syb. shifter bushings under shifter, brass shifter cable bushings, B&M short shifter, and all new OEM shifter cables...
Megan Racing coilvers, front & rear sturt bars, all poly bushings, 3000 n\t duel piston calipers (front), new OEM rear calipers, dba rotors, Hawk pads, blue 600 racing brake fluid, hard brake lines....
Parts Wishlist
Front and rear sway kits (???), carbon hood, hatch, doors, gas door!!
1/8 Mile E/T
9
1/8 Mile MPH
89
Timeslip Details
Track Name : atco
Fuel Used : Pump gas
Vehicle Weight : 2800
Tires : Street Radials
Dyno HP
667 whp
606 lb/ft
Dyno Type
DynoJet
Dyno Shop Name
dynoworks
Dyno Session Details
Boost : 32
4seaer
More in 1G DSM
Share this Vehicle
